Hello, i’m trying out the cubcell board (HTCC-AB01) with two small solar cell panels, they are just outside the requriments for connecting to Vs (Voc is about 4 Volts). So I tested with both connecting them in series and in parallell for comparing the performance. However it turned out that when connected to the board even when in series the voltage over the cells became 4 V. Also the current where slightly higher when in series.
TL;DR Solar cells in series Voc =8.3 jumps to 4.1 V after connecting to Vs
Do you have any suggestions why it behaves like that?
