HTCC-AB01 connect to WiFi LoRa 32(V2)
Currently, HTCC-AB01 connect dht11 sensor as sensor node. I would like to use WiFi LoRa 32(V2) as lora gateway. I don’t know how to send data from HTCC-AB01 to WiFi LoRa 32(V2).
although lorawan region same as both side, WiFi LoRa 32(V2) could not receive any lora packet.
thanks.
Hey, did you manage to find a solution for this?
If you want to use lorawan, you must have a dedicated gateway!
Point to point communication can be used between nodes.
