Hello everyone, first of all, let me clarify that I am new and although I try to read a lot, the language is still difficult for me, so I ask you to please be patient and if I make a mistake, please do not close the forum so I can remedy it. Well I don’t know how to modify my other post so I created a new one. I explain: I bought an HT-M7603 indoor gateway from Heltec AND A LoRa 32 (V3) WiFi, I am learning all this about microcontrollers and Lorawan, I have created an MQTT server and the cloud performance tests are fine, but I cannot communicate the WiFi LoRa 32 (V3) through my gateway (HT-M7603), I follow the node_example.ino, I try to follow the advice in the code but I can’t find the info to modify the correct data, I can’t find a hello world like in other forums of connectivity communication, to test code, there are too many variables, could you help me with the API or some functional example. I have configured it as a sender but I don’t know what api to use or where to start.
/* Heltec Automation example
* HelTec AutoMation, Chengdu, China
* www.heltec.org
* this project also realess in GitHub:
* https://github.com/HelTecAutomation/ASR650x-Arduino
#include "LoRaWan_APP.h"
#include "Arduino.h"
/*if defined SENDER, the node work as sender
* the node will send data {0x00,0x01,0x02,0x03} every 2 seconds
* subscribe UPlink Topic(like "GWID/60FB00FFFE63A3E1/UP" ) will get message like this.
* {"freq":486.300000,"datr":"SF7BW125","rssis":-9,"lsnr":12.8,"rssi":-10,"size":4,"data":"AAECAw=="}
* The freq "486.3" is based on RF_FREQUENCY in the code.
* The data "AAECAw==" is base64 encode of data({0x00,0x01,0x02,0x03}).
* The datr "SF7BW125" is based on the LORA_BANDWIDTH and LORA_SPREADING_FACTOR in the code.
/*if defined RECEIVER, the node work as reciver
* publich a message like {"freq":486.3,"datr":"SF7BW125","size":4,"data":"AAECAw=="} with Downlink Topic(like "GWID/60FB00FFFE63A3E1/DOWN" )
* the node will recive data {0x00,0x01,0x02,0x03} and print it on the UART Serial.
#define SENDER
//#define RECEIVER
#define RF_FREQUENCY 915300000 // Hz
#define TX_OUTPUT_POWER 17 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
uint8_t data[]={0x00,0x01,0x02,0x03};
void OnTxDone( void );
void OnTxTimeout( void );
typedef enum
LOWPOWER,
RX,
TX
}States_t;
States_t state;
Radio.Init( &RadioEvents );
#ifdef SENDER
state=TX;
#ifdef RECEIVER
state=RX;
switch(state)
case TX:
delay(2000);
Radio.SetTxConfig( MODEM_LORA, TX_OUTPUT_POWER, 0, LORA_BANDWIDTH,LORA_SPREADING_FACTOR, 1,8, false,true, 0, 0, false, 3000 );
Radio.Send( data,4 );
state=LOWPOWER;
case RX:
Radio.SetRxConfig( MODEM_LORA, LORA_BANDWIDTH, LORA_SPREADING_FACTOR,1, 0, 8, 0, false, 0, false, 0, 0, true, true );
Radio.Rx( 0 );
state=LOWPOWER;
case LOWPOWER:
lowPowerHandler();
Serial.print("TX done......");
state=TX;
Radio.Sleep( );
Serial.print("TX Timeout......");
state=TX;
Serial.printf("rececived %d bytes with rssi %d,snr%d\r\n",size,rssi,snr);
Serial.printf("data:");
for(int i=0;i<size;i++)
Serial.printf("0x%02X ",payload[i]);
Serial.printf("\r\n");
delay(10);
Could you help me find the communication libraries of these two teams please. I hope I’m not annoying, I couldn’t edit my other post
Blockquote
