HT-M2808 solana wallet connected
Hi everyone, I have a fairly serious problem, I have two Heltec HT-M2808 (Eu868) hotspots. I lost the seed phrase of the solana wallet to which the two hotspots are connected. How can I disconnect that wallet with another one to connect with Phantom Wallet? I would hate to resell them as spare parts. Thank you for helping me
Not saying you won’t get support here, but I know that the Discord server is more active w.r.t. mining. Most users are here for the microcontrollers/boards. So you might want to check out the Discord server.
You can’t “disconnect” the old wallet without having access to it.
Those hotspots are now useless for helium mining.
Simplifying:
Hotspot is assigned to the wallet via crypto key that is in a chip soldered to the hotspot mainboard.
You cannot “disconnect” it without access to the wallet. You cannot change the key in the chip.
Only way would be to unsolder the old chip and solder there a new one (or a one that is connected to a wallet which you have access to).
There is no way to “reset” it to factory condition in terms of helium mining (resetting the key or connection to wallet).
And it’s like that for all helium miners out there, not only the ones made by Heltec.
