I have Heltec HT-M2808. The hotspot was added on Oct 19th. Everything worked fine. The hotspot syncronized in an hour or so. I moved it to a different location and after the last firmware upgrade (V1.1.6) it stopped working. Basically out of sync. I logged into the hotspot through the diagnostic page using hotspot IP, did RESTART and after that did RESET. The latest block height matched. But when I pair with my phone and go to Diagnostic Page in Helium App, Blockchain Sync shows 0%. Plus firmware in Helium App Diagnostic Report shows 2019.11.06.0 while in Heltec Diagnostic page shows 2021.10.29.0_GA. Tried restarting and resetting hotspot but it didn’t help. How to fix this issue?
HT-M2808 Not Syncing with blockchain
We have repaired it for you remotely, and you can now check whether the status is normal.
I have same problem please help me. Why write 0% sync when I did it all over again and it worked normally
