My hotspot as long periods without any sort of activity (2 or 3 challenges per day, but that’s about it).
I checked the lora logs, and i’m getting what appears to be some valid witnesses, but they never show on Helium explorer, even though they appear to be well within the parameters to be valid, here are a few of 52 size packets.
Feb 23 18:23:13 JSON up: {“rxpk”:[{“tmst”:931167116,“chan”:2,“rfch”:1,“freq”:868.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF7BW125”,“codr”:“4/5”,“rssis”:-104,“lsnr”:4.0,“rssi”:-104,“size”:9,“data”:“BH+2Bjb/Av4B”}]}
Feb 23 18:25:13 JSON up: {“rxpk”:[{“tmst”:1025856300,“chan”:7,“rfch”:0,“freq”:867.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-134,“lsnr”:-15.0,“rssi”:-119,“size”:52,“data”:“QDDaAAGBA8P0AByOANUMtfTZb5/m4Sl9occHXaTYRQWJeulcxG/gZK8HZCkB4DTU8GPzww==”}]}
Feb 23 18:28:43 JSON up: {“rxpk”:[{“tmst”:1286310796,“chan”:6,“rfch”:0,“freq”:867.700000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-130,“lsnr”:-16.8,“rssi”:-113,“size”:52,“data”:“QDDaAAHrgdabACY2AJmTJ/MAOQmees1633RAs7Le5G+FSNkpUJv+MijCoX6yWRulwNsAyw==”}]}
Feb 23 18:34:13 JSON up: {“rxpk”:[{“tmst”:1559568844,“chan”:5,“rfch”:0,“freq”:867.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-127,“lsnr”:-15.2,“rssi”:-112,“size”:52,“data”:“QDDaAAGpY6y9AKDZACbuuNB+UqCO4qaaRhMvmji+i2t8ILmDauavJUn+ZX2IZ1/84BScAw==”}]}
Feb 23 18:40:13 JSON up: {“rxpk”:[{“tmst”:1976124916,“chan”:6,“rfch”:0,“freq”:867.700000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-121,“lsnr”:-7.2,“rssi”:-114,“size”:52,“data”:“QDDaAAF5LkvkAOcGAO8BnyJKWUC6FnxSiqNx4crTHkLXrn3SfirwyIROJxb1aN35F/52nw==”}]}
Feb 23 18:56:43 JSON up: {“rxpk”:[{“tmst”:2929023220,“chan”:7,“rfch”:0,“freq”:867.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-114,“lsnr”:-1.0,“rssi”:-113,“size”:52,“data”:“QDDaAAGnFSTNAGw1ACGJv6Buw8BAVqUF7Y6rdHf9Vfpv/hYoAQGqWRju20nsPxWngSkEkQ==”}]}
Feb 23 18:57:43 JSON up: {“rxpk”:[{“tmst”:2989504884,“chan”:7,“rfch”:0,“freq”:867.900000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-122,“lsnr”:-7.5,“rssi”:-115,“size”:52,“data”:“QDDaAAFbfB2dAP0bAI6opOe03vY2V/HRWjmHMc0kiyRLOELITf9z8+pLAk/kCub2HS7mvA==”}]}
Feb 23 18:57:44 JSON up: {“rxpk”:[{“tmst”:3011259748,“chan”:0,“rfch”:1,“freq”:868.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF12BW125”,“codr”:“4/5”,“rssis”:-130,“lsnr”:-17.8,“rssi”:-112,“size”:52,“data”:“QDDaAAEln8o5AO8LAKjg3WBYaWFptepugKCsuo/edXBNXC8sQIc4ZbNogiN7ecppej9+tA==”}]}
I’m also attaching an image with the dashboard where everything appears to be completely fine. In the Helium explorer, hotspotty and heliumstatus everything is pinging fine and i’m not relayed aswell. So, i really have no answer for this and hope someone knows something.
