HT-M01S Set Static IP
Hi Everyone!
Is there a way to set static IP to HT-M01S instead of using DHCP? If not is this action on the development roadmap for next firmware versions?
Best Regards,
Winner Martins
There are currently no plans to add this feature. You can bind the IP and MAC addresses through the router.
Thank You, Shaffer!
As I understood I will need to consider a more elaborated gateway (HT-M01 or HT-M02) on my solution. I liked this one because the setup was very easy to do.
Best Regards,
Winner Martins
