I have recently bought an AU 915 mhz HT-M01S gateway and successfully configured the gateway over LAN. The gateway is set to listen on channel AU 915, Channels 8-15,65 (TTN Australia). I have also tried on Channels 1-7.
I have the gateway set up with the large antenna connected to the LoRa port, and the small antenna to the wifi port (like on the amazon images from the heltec store).
I have a LoraWAN device on AU915 transmitting on channel 8 in the same room, and also a number of other AU915 LoRa nodes nearby that are known to be working. My HT-M01S shows “null” for both the Rx and Tx after 48 hours of testing.
Firmware v1.3 (Can’t seem to get the device to show on COM port to upgrade to 1.4).
What might be the problem?
