17/03/2021 17:59:58.880 [RX] -
Heltec HT-M01S firmware Rev V1.2
NET MODE : WIFI
WiFi SSID : AMPA
WiFi PASS : amp090875
SERVER ADDR : router.us.thethings.network
SERVER PORT : 1700
REGION : US915
CHANNNELS : 0-7,64
TIME ZONE : UTC+0
Connecting to AMPA
get time from : europe.pool.ntp.org
Time synchronized : 2021-03-17 12:30:10 CET
Local UDP port=1700, Connection successful
LoraWan Server : router.us.thethings.network, port: 1700
GateWayID: 7C9EBDFFFFFC13F0
Gateway Starting…
INFO: /lora_conf_US915.json does contain a JSON object named SX1301_conf, parsing SX1301 parameters
INFO: lorawan_public 1, clksrc 1
INFO: no configuration for LBT
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 902700000, RSSI offset -164.000000, tx enabled 1, tx_notch_freq 0
INFO: radio 1 enabled (type SX1257), center frequency 903400000, RSSI offset -164.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
INFO: FSK channel 8 disabled
INFO: concentrator started, packet can now be received
stat update: <111> {“stat”:{“time”:“2021-03-17 12:30:13 CET”,“rxnb”:0,“rxok”:0,“rxfw”:0,“ackr”:0.0,“dwnb”:0,“txnb”:0}}
