Configured the HT-M01 with rpi zero w through SPI.
The gateway is constantly visible at heltec cloud, no problems here.
I’m using the CN470 config. But not a single packet is received from the nodes.
Meanwhile when I power up the HT-M00 gateway then I can see the uplink packets coming from nodes.
The global_conf.js I have the similar freq setup for radio_1 and radio_2 as for htm-00 = 472100000 and 472300000.
The status of the lrgateway service at raspberry pi also shows 0 received packets.
The node is running in 1 channel mode. But no data received from node by the gateway no matter how long.
I there any way I can see the status of the gateway on which channels/frequencies it is running at the moment?
