Hello -
I recently purchased the M00. I ordered the US/915Mhz version.
When trying to get it set-up, the original channel configuration was for 868.1 and 868.3, which appear to be the EU channels. Is the hardware identical between the US and EU version? If yes, what frequencies should I enter in the setup to make this work in the US?
Also, I’m using nodes from other manufacturers. I see this comment in the instructions:
“When using the HT-M00 gateway, using nodes other than the company’s CubeCell series, you need to change the node’s preamble length to 16 (default is 8). If the preamble length is not modified to 16, only SF7 can be received.” How do I make this modification?
