HT-HC32 license?
hello,
I try to use example “As_VideoWebServer”.
When I get the board, it is ok using the example of “As_VideoWebServer”, but after I upload an example of " halow scan" I see the message through serial monitor below.
why? maybe, in Arduino, I set the “Erase All flash~” to test other board.
Thanks,
ESP32ChipID=64250597BACC
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x1 (POWERON),boot:0x29 (SPI_FAST_FLASH_BOOT)
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3818,len:0x508
load:0x403c9700,len:0x4
load:0x403c9704,len:0xad0
load:0x403cc700,len:0x29d8
entry 0x403c9880
Start WiFi HaLow
http://www.heltec.cn/search/
Why not ask ChatGPT first?
Or you could follow the link that you were given in the message that you posted above.
Formatting log output with </> would be better.
Hey, Guys.
First, english is not my language.
Do you think I am not searching the web or try to go the link? I write chip-id and see the result. and after??
I dont know! So, I post here.
Do you hate chatgpt? So what? But It is a good for beginner like me.
In your log, you see
If you follow that link, you can input your ChipID and you will get a license.
If you then Google for “Heltec license”, the first website is from Heltec and it tells you how to activate this license.
And yes, I checked: ChatGPT is able to perfectly tell this, likely even in your own language!
Thank you for reply.
I go to use ChatGPT.
That pretty much covers most people on here.
There is no evidence of that, so we can only wonder.
Neither do we, because you didn’t give us the detail of what the response was.
If you provide the info you see, we can help you faster.
Experience from answering questions on forums leads me to believe that it can help someone who knows enough to get something started to help to solve single issues within a project.
And it is very good at answering questions that you can find via Google.
But for beginners, it leads them to bypass the fundamental learning that’s required to make good progress but gives the illusion that they now know something.
You can get ChatGPT to help start your car as it can read the manual for you. But it’s not so good at how to deal with a particular set of circumstances if you don’t have the knowledge to describe the situation properly, knowledge that is fundamental.
You missed the point, you need to follow the link, follow the instructions and if they don’t work for you, tell us exactly what response it gave.
