Drawing reference to the datasheet of HT-CT72, there are 7 GPIO pins (GPIOs 3,4,5,6,7,8&10) connected to the LoRa Chip. Could you advise if these pins can be used for IO purposes such as PWM output or ADC input? Does it cause the LoRa Chip to malfunction? Does the Lora Chip feed signals to these shared pins and interfere with the IO functions?
Any advice and experience sharing about using these GPIOs are appreciated. Thank you.
