Can I power the HT-C62 with a LIPO battery, in the data sheet it says 3.3v max. Lipo are 3.7V
if LIPO can’t work then what other options are possible? HT-VT62 is highly integrated module, and I would really prefer avoid additional logic/components to the design.
HT-CT62 on LIPO batteries
This is not recommended. HT-CT62 uses the esp32c3 chip with a maximum voltage of 3.6V.
Thank you, this is helpful.
What is the recommended battery arrangement for a very size and power consumption sensitive application. my original intention was to use a 80mah tiny LIPO battery.
Suggest adding LDO or other level conversions
