How would I implement two separate interrupts for wake up by GPIO
How would I implement two separate interrupts for wake up by GPIO?
For example I want to use both GPIO6 and GPIO9 as interrupts to wake up from sleep.
Does anyone have an example they can post or an idea on how to get started?
I am using the 1/2 AA module.
Here is the code that works and wakes up from sleep with one GPIO interrupt - GPIO6
#include “Arduino.h”
#define INT_GPIO GPIO6
#define timetillsleep 1000
static TimerEvent_t sleep;
uint8_t lowpower=1;
#include “LoRaWan_APP.h”
  • set LoraWan_RGB to 1,the RGB active in loraWan
  • RGB red means sending;
  • RGB green means received done;
    #ifndef LoraWan_RGB
    #define LoraWan_RGB 0
#define TX_OUTPUT_POWER 20 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 10 // [SF7…SF12]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 1000
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
double txNumber;
int16_t rssi,rxSize;
void DoubleToString( char *str, double double_num,unsigned int len);
void onSleep()
Serial.printf(“Going into lowpower mode. Press user key to wake up\r\n”);
lowpower=1;
void onWakeUp()
delay(10);
if(digitalRead(INT_GPIO) == 0)
Serial.printf(“Woke up by GPIO, %d ms later into lowpower mode.\r\n”,timetillsleep);
lowpower=0;
TimerStart( &sleep );
boardInitMcu( );
txNumber=0;
rssi=0;
Radio.Init( &RadioEvents );
//Serial.begin(115200);
pinMode(INT_GPIO,INPUT);
attachInterrupt(INT_GPIO,onWakeUp,FALLING);
TimerInit( &sleep, onSleep );
Radio.Sleep( );
while(lowpower){
lowPowerHandler();
Serial.printf(“woken up-with just this stops at 6 mcu cycles\r\n”);
//delay(10);
//txNumber += 0.01;
txNumber += 1;
sprintf(txpacket,"%s",“Hello world number”); //start a package
sprintf(txpacket+strlen(txpacket),"%d",txNumber); //add to the end of package
DoubleToString(txpacket,txNumber,3); //add to the end of package
//turnOnRGB(COLOR_SEND,0); //change rgb color
Serial.printf("\r\nsending packet “%s” , length %d\r\n",txpacket, strlen(txpacket));
void DoubleToString( char *str, double double_num,unsigned int len) {
double fractpart, intpart;
fractpart = modf(double_num, &intpart);
fractpart = fractpart * (pow(10,len));
sprintf(str + strlen(str),"%d", (int)(intpart)); //Integer part
sprintf(str + strlen(str), “.%d”, (int)(fractpart)); //Decimal part
First a note: On Discourse-based forums, you can use triple backticks to ensure that source code is pretty-printed (and highlighted) as source code, rather than all indentation disappearing, like for instance:
int main() {
 // your code here
which would be shown as:
int main() {
 // your code here
To answer your question:
I’ve needed to do similar things in the past. (For me, it was a wakeup which could happen either from a timer or from a button press and I had to see which of the two it was).
The most pragmatic approach which to my knowledge is used frequently in these kinds of situations, is to (re-)read the GPIO-pin(s) once you’ve woken up, to check which one it was that triggered the wakeup.
Thanks for the tip on posting and my question.
My 1st interrupt is on the rising edge and stays high for 2 seconds.
The second interrupt is on a falling edge maybe low for a few hundred milliseconds so if I wait a second and then re-poll like you said in a one second this may work.
I’m not sure if this is possible in sleep (or even at all) - but have you tried using individual pins as interrupts? I can’t find a good manual for the ASR650x that tells me which pins support being interrupts - but you could try the following:
void onWakeUpGPIO1(){<insert_function_here>}
void onWakeUpGPIO2(){<insert_function_here>}
pinMode(GPIO1,INPUT);
attachInterrupt(GPIO1,onWakeUpGPIO1,RISING);
pinMode(GPIO2,INPUT);
attachInterrupt(GPIO2,onWakeUpGPIO2,FALLING);
Yes thanks for the suggestion - I did this and had to add some delays but it seems to be working okay now.
