Hello, I have a Wifi Kit 32 that was working fine with a rotary encoder that I ran through a 74HC14 and into pins 26 for pushbutton , 33 for Data, and 36 for Clock. The LCD displayed 0-100% depending on rotation. I moved everything from a breadboard to a perf-board and I have now lost the LCD display as well as the serial Display. When I check the signal at the corresponding pins with an oscilloscope they all are still getting the correct signal. The encoder and Schmidt trigger are getting 3.3v and the Wifi Kit 32 is plugged into the USB.
I have uploaded the factory demo and its not displaying either anymore. Is there a major reset or is it garbage?
