With the latest environment 0.0.7 i cannot use older ESP32 V2
It says on booting:
ESP32ChipID=8CF0FE7EB994
But on the latest environment it is not possible provide the license anymore.
It says on booting:
Thank you, that worked.
I tried to get a license for esp32 Lora V2 with Chip ID: C0F8FE7EB994
but that did not work on http://www.heltec.cn/search/
Can you pls add that board ID to your Database?
Thank you
hi navi, i don’t won’t open a new topic, but I have the same problem with my esp32 Lora V2 with Chip ID: E81C46BD9E7C, maybe you can help me?
Thx
All have been added.
I can’t get there. What do I have to do exactly? How do I use the AT command? I use the ESP32-lora board v2 and Arduino IDE v2 or v1.8.
i can create a license, but the modul loop at mcu.init
regards
ThomaDr
You need to connect your board through the USB COM Port and then send the Commands.
I tried this AT-Command through Arduino-Serial-Term., PLatformIO Terminal, Tera Term. Non of them responded to the command.
I’m really frustrated with the recent changes that you have made to the library as my old firmware doesn’t work anymore or works with strange beavoiur.
basic loRaWAN OTA example crashes after receiving the join packet from the gateway!!.
please give us a clear instructions about how to activate/use the library properly with which Hardware(V1, V2, V3).
where i can find the licence page? i have many loras to get this, if u can help plz!
