Hello, I could not find any docs to program wireless shell. What external hardware is required to program wireless shell.
How to program wireless shell?
You can refer to this document.
Thanks. However my issue is wireless shell does not have usb port. How should I connect it to the computer to program it via Arduino ide? Can I use Arduino uno to program it or do I need any extra hardware programmer?
This is that the module needs to add an external circuit by itself. If you can’t add it yourself, it is recommended to buy a Wireless Stick, which has a USB interface and can be programmed directly.
Thanks. May you please tell me which circuit I need to add? Where I can find it?
Thanks. I will try it.
