I just have ordered from amazon the lora module node from heltec. I am not getting how can I install antenna on the PCB? Is there a guide? can/should I solder it? the space looks very small.
there is a ipex antenna connector.
you can buy antennas with that connector to use directly or use an adapter to sma for example
