Hello, community,
I’m working with the Cubecell AB01 V2 and need to implement two digital serial (UART) ports to control two sensors using RS485 modules . So far, I’ve used the "softSerial.h" library, but it only supports one serial port at a time.
Could anyone recommend a library compatible with the Cubecell AB01 V2 that allows controlling two serial ports simultaneously ? I’d also appreciate any examples or suggestions on how to configure them properly.
Thank you in advance for your help!
