How to disable brown out reset w ESP32-S3?
I am using the Wireless Stick Lite V3 parts which have the esp32-S3 CPU. I wish to disable the brown out reset, instead relying on my own battery voltage level monitoring in SW. I don’t see an API to enable me to disable the default via Platformio arduino framework setting SW environment. Any suggestions?
Have you found a solution?
