I am using the example code, LoraWan_HDC1080, which is successfully sending data to Chirpstack. The payload is on base64: data:“pHDFQc3Mg0IQmQ==”
unsigned char *puc;
puc = (unsigned char *)(&temperature);
appDataSize = 10;
appData[0] = puc[0];
appData[1] = puc[1];
appData[2] = puc[2];
appData[3] = puc[3];
puc = (unsigned char *)(&humidity);
appData[4] = puc[0];
appData[5] = puc[1];
appData[6] = puc[2];
appData[7] = puc[3];
appData[8] = (uint8_t)(batteryVoltage>>8);
appData[9] = (uint8_t)batteryVoltage;
Can anyone give some advice on what kind of encoding this is or how I would decode the data?
