How to avoid channel jamming in Lora basic sender
Hardware: HTCC-AB01
The program is base on
  1. LoRaSender_ReadBattery.ino
  2. hdc1080demo.ino
If I have many nodes, how to aovid channel jamming? i.e: list the channel before sending?
Code:
Method 1: host polling mode
The host polling mode is the way that the host calls one by one. The principle is very simple, and the response is realized by roll call. If the master sends the message to slave 1, only slave 1 can respond to the master because the slave has different address settings. After receiving the command from the host, slave 1 uploads the data to the host. The host then poll other slave data in the same polling mode
Method 2: from the machine timing upload mode
The principle of timing upload mode is that the host broadcasts and sends information to the slave. After receiving the host information, the slave synchronizes the time, and then uploads the information according to the time we set. For example, after the host sends the information, the upload time of slave 1 is 1 second, and that of slave 2 is 2 seconds… And so on
Method 3: active upload from slave
Slave active upload, Lora module has its own RSSI function networking mode is relatively reliable active upload mode. This transmission method is to detect the RSSI signal strength in the environment when the slave needs to upload data. If the RSSI strength in the current environment is larger, wait for the RSSI value to become smaller before uploading. If the upload is successful, the host will give feedback to the slave and decide whether to upload again. However, this method is not suitable for Lora module without RSSI function, because the more frequently the slave uploads, the higher the probability of communication failure, which is what we call co frequency interference.
Summarizing the above three methods, they all adopt the principle of staggering the upload time of the slave module, so as to solve the problem of co-frequency interference.
As I know LoraWan has similar features.
Is it possible to make a Lora receiver compatible with LoraWan node?
Any example?
