Require watchdog support in CubeCell but couldn’t find any example or way to add watchdog in application, so, can someone explain how to add it? or watchdog example would be better to understand
Thank you in advance for your support
How to add watchdog support in cubecell?
The ASR650X chip has an internal watchdog. But this watchdog function is very bad… the maximum dog feeding time only 2S
It means if the system is in the deep sleep status, the system need to wake up every 2 seconds to feed the dog, that’s very unfriendly for low power features.
So, you may need consider add an external watchdog chip or module.
How would I enable this internal watchdog function of the ASR650X Chip?
With my current use that is not a concern, but space is! So the internal watchdog even as it is unfriendly would still work for me, How would I enable it?
Can you not switch the watchdog off after it has sucesfully completed X task?
you could use the TPL5010.
I need a watchdog too in my circuit and the TPL5010 “only” needs to get feed every 7200s (2h).
regarding to the datasheet the current consumption is about 35nA and therefore suitable for low power circuits. Anyway 2h is much better than 2s, but you guys know maybe an other external watchdog who has to be feeded even less? @Supporter
hi,
you can refer this code:
Hello WASN,
maybe i’m wrong but using the below code seems to keep the system asleep without interruption and when it wakes up it feeds the WDT properly does it’s think and go back to sleep…
Note: innerWdtEnable(true); then the module never goes to sleep, and keep waking up as you said to feed the WDT so the trick is to set to false and find a way to feed the WDT when awake.
void setup()
  /* Enable the WDT, autofeed is set to false we will feed it our self */
  innerWdtEnable(false);
void loop(){
  switch (deviceState)
  case DEVICE_STATE_INIT:
#if (LORAWAN_DEVEUI_AUTO)
#if (AT_SUPPORT)
    getDevParam();
    printDevParam();
  case DEVICE_STATE_JOIN:
    LoRaWAN.join();
  case DEVICE_STATE_SEND:
    CySysWdtEnable(); //enable the WDT
    prepareTxFrame(appPort);
    LoRaWAN.send();
  case DEVICE_STATE_CYCLE:
    txDutyCycleTime = appTxDutyCycle + randr(0, APP_TX_DUTYCYCLE_RND);
    CySysWdtDisable(); //disable the WDT before going to sleep
  case DEVICE_STATE_SLEEP:
    LoRaWAN.sleep();
 Serial.print("."); //it will stop printing when it's in deep sleep.
 feedInnerWdt(); //as long as we are awake continue to feed the WDT ....
what do you think? or am i wrong here…?
Hi jayjay,
I think your thinking is right - no interrupts while sleeping.
It might be a good solution in combination with the real watchdog.
The current watchdog implementation from Heltec seems to use the WCO_WDTx timer(s), not the real watchdog, when I’m correct.
A WCO_WDTx timer will generate an IRQ when not fed, but not force a system reset after missed feeding times, like the real dog. A good watchdog should bite when needed - not just bark, right?
In fact these WCO_WDT timers would make a great deep sleep timer: 0 - 2^17 sec (36.4h) sleeping time, or way longer even, when putting all 3 timers in cascade.
HI peterm,
thanks for the updates, please take a look my proposed solution below and tell me what do you think?
Hi jayjay,
Please see my comments in the other thread lowPowerHandler(); & TimerLowPowerHandler()
Are my concerns re: “too soft” WDT implementation justified, or did I miss something?
I think the problem is that there is not a function called  innerWdtDisable (true);
As innerWdtEnable(false); means start inner watchdog timer without interrupt timer auto-feed
and innerWdtEnable(true); means start inner watchdog timer with interrupt timer auto-feed.
innerWdtEnable(true);  will start interrupts but innerWdtEnable(false);  does not stop the interrupts once started.  And therefore  wakes the device  from sleep every second to service the WDT but strangely does not check if a WDT  time out has occurred and reboot.
So found the solution before sleep to turn off the WDT interupt using  wdt_isr_Disable();     // turns off the interrupt
This method does mean there is no WDT protection when asleep. But does put the device into lowest power possible. I don’t have a meter to check this. But my sub code does report that sleep is happening correctly without waking for the full duration of the sleepTime period.
So now my pre sleep code looks like this
Serial.flush();
Serial.end();
Wire.end();
pinMode(GPIO4, INPUT_PULLDOWN);
digitalWrite(Vext,HIGH); // turn off power to the sensor
innerWdtEnable(false);   //  set inner watchdog to self feed
wdt_isr_Disable();     // disable the WDT interrupt before sleep  ******
CySysWdtDisable();
TimerSetValue( &wakeUp, sleepTime*1000 );
TimerStart( &wakeUp );
CySysPmDeepSleep;   // use to turn off sys wdt
state=LOWPOWER
Although all this does make wonder what sort of scenario with auto feed WDT would not spot infinite loops or system lock up would even trigger a Reboot while interrupt routine was still in operation. As it would require a interrupts failure to happen for this to occur. So really manual feed of the WDT is the only method worth while to catch infinite loops or crashed core.
