How do I reinstall the factory firmware/OS on HT-M7603-1231?
Friends, I did a hard reset and lost the possibility of choosing the MQTT option and also the interface that came from the factory. Could someone help me return to the version that came when I bought it.
Now when I update it sends me to this URL: But it doesn’t let me update anything.
http://minerback.heltec.cn/download/patch_7603/
gateway:
I don’t understand anything and I don’t know where to ask, I don’t find it clear or friendly at all.
The factory login name of the device is root, and the password is heltec.org. If the user has changed the password, use the changed password.
Once logged in, enter the following command:
rm -rf init_M7603* && wget http://minerback.heltec.cn/download/reset_M7603.sh && chmod +x reset_M7603.sh && ./reset_M7603.sh EU868
Upon completion, the ssh login password is restored to heltec.org;
web page passwords are not recovered;
The hotspot password is also restored to heltec.org.
Confusing is what firmware you are updating, this product has not provided any firmware updates since it was shipped.
Unfortunately, I don’t have a way to show where and how I did the firmware update process, I don’t have screenshots and I don’t have a way to log back into the device, but I can remember to do it in the tab within the HT-M7603 web interface.
I can enter through AT commands, but using those codes there are files that cannot be copied "rm -rf init_M7603* && wget http://minerback.heltec.cn/download/reset_M7603.sh && chmod +x reset_M7603.sh && . /reset_M7603.sh EU868
I will try to put the code that my serial monitor shows,
I tried to add these files but I can’t get luci to run
source: http://minerback.heltec.cn/download/patch_7603/
manual 7628N:
This web interface cannot be loaded as you see it appears powered by luci
http://minerback.heltec.cn/download/HT-M7603/
I prefer not to comment on this heltec manual or documentation:
https://docs.heltec.org/en/gateway/ht-m7603/quick_start.html
firmware:
For now, that’s all I can find, maybe I need to know how to install everything correctly.
BlockquotePreformatted text
19:29:59.471 ->
| | | | | | | |/ / |____ | / / / _ \ / _ \ /\
19:29:59.471 ->
| || | | | | ’ / / / / /_ | () | | () | / \
19:29:59.504 ->
| __ | | | | < / / | '_ \ > _ < > _ < / /\ \
19:29:59.504 ->
| | | | | |____ | . \ / / | () | | () | | () | / ____ \
19:29:59.504 ->
| ||_\ // _/ _/ __/ /_/ _\
19:29:59.537 ->
19:29:59.537 ->
https://github.com/gnubee-git
19:29:59.537 ->
-------------7688A build May 23 2020 14:40:12--------------------
19:29:59.570 ->
19:29:59.570 ->
19:29:59.570 ->
Please choose the operation:
19:29:59.570 ->
1: Load system code to SDRAM via TFTP.
19:29:59.570 ->
2: Load system code then write to Flash via TFTP.
19:29:59.603 ->
3: Boot system code via Flash (default).
19:29:59.603 ->
4: Entr boot command line interface.
19:29:59.603 ->
5: Load system code then write to Flash via Httpd.
19:29:59.603 ->
7: Load Boot Loader code then write to Flash via Serial.
19:29:59.649 ->
9: Load Boot Loader code then write to Flash via TFTP.
19:29:59.649 ->
9 8 7 6 5 4 3 2 1 0
19:30:09.550 ->
19:30:09.550 ->
3: System Boot system code via Flash.
19:30:09.550 ->
Booting image at bc050000 …
19:30:09.550 ->
Image Name: MIPS OpenWrt Linux-5.10.176
19:30:09.594 ->
Image Type: MIPS Linux Kernel Image (lzma compressed)
19:30:09.594 ->
Data Size: 2208698 Bytes = 2.1 MB
19:30:09.594 ->
Load Address: 80000000
19:30:09.594 ->
Entry Point: 80000000
19:30:09.594 ->
Verifying Checksum … OK
19:30:11.624 ->
Uncompressing Kernel Image … OK
19:30:15.001 ->
No initrd
19:30:15.001 ->
Transferring control to Linux (at address 80000000) …
19:30:15.037 ->
Giving linux memsize in MB, 128
19:30:15.037 ->
19:30:15.037 ->
Starting kernel …
19:30:15.037 ->
19:30:15.037 ->
[ 0.000000] Linux version 5.10.176 (builder@buildhost) (mipsel-openwrt-linux-musl-gcc (OpenWrt GCC 11.2.0 r20134-5f15225c1e) 11.2.0, GNU ld (GNU Binutils) 2.37) #0 Thu Apr 27 20:28:15 2023
19:30:15.070 -> [ 0.000000] Board has DDR2
19:30:15.070 -> [ 0.000000] Analog PMU set to hw control
19:30:15.070 -> [ 0.000000] Digital PMU set to hw control
19:30:15.070 -> [ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
19:30:15.104 -> [ 0.000000] printk: bootconsole [early0] enabled
19:30:15.104 -> [ 0.000000] CPU0 revision is: 00019655 (MIPS 24KEc)
19:30:15.104 -> [ 0.000000] MIPS: machine is HILINK HLK-7628N
19:30:15.138 -> [ 0.000000] Initrd not found or empty - disabling initrd
19:30:15.138 -> [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
19:30:15.138 -> [ 0.000000] Primary data cache 32kB, 4-way, PIPT, no aliases, linesize 32 bytes
19:30:15.171 -> [ 0.000000] Zone ranges:
19:30:15.171 -> [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
19:30:15.171 -> [ 0.000000] Movable zone start for each node
19:30:15.212 -> [ 0.000000] Early memory node ranges
19:30:15.212 -> [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
19:30:15.212 -> [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
19:30:15.249 -> [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32480
19:30:15.249 -> [ 0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
19:30:15.282 -> [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
19:30:15.282 -> [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
19:30:15.282 -> [ 0.000000] Writing ErrCtl register=00000000
19:30:15.319 -> [ 0.000000] Readback ErrCtl register=00000000
19:30:15.319 -> [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
19:30:15.351 -> [ 0.000000] Memory: 121264K/131072K available (5702K kernel code, 619K rwdata, 696K rodata, 1228K init, 210K bss, 9808K reserved, 0K cma-reserved)
19:30:15.351 -> [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
19:30:15.386 -> [ 0.000000] NR_IRQS: 256
19:30:15.386 -> [ 0.000000] intc: using register map from devicetree
19:30:15.386 -> [ 0.000000] CPU Clock: 580MHz
19:30:15.386 -> [ 0.000000] timer_probe: no matching timers found
19:30:15.418 -> [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6590553264 ns
19:30:15.418 -> [ 0.000012] sched_clock: 32 bits at 290MHz, resolution 3ns, wraps every 7405115902ns
19:30:15.493 -> [ 0.015499] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
19:30:15.526 -> [ 0.087683] pid_max: default: 32768 minimum: 301
19:30:15.526 -> [ 0.097019] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
19:30:15.526 -> [ 0.111354] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
19:30:15.561 -> [ 0.129219] dyndbg: Ignore empty ddebug table in a CONFIG_DYNAMIC_DEBUG_CORE build
19:30:15.561 -> [ 0.148613] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
19:30:15.594 -> [ 0.168001] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
19:30:15.594 -> [ 0.181504] pinctrl core: initialized pinctrl subsystem
19:30:15.628 -> [ 0.196989] NET: Registered protocol family 16
19:30:15.692 -> [ 0.206627] thermal_sys: Registered thermal governor ‘step_wise’
19:30:15.728 -> [ 0.274738] clocksource: Switched to clocksource MIPS
19:30:15.728 -> [ 0.298052] NET: Registered protocol family 2
19:30:15.728 -> [ 0.306936] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
19:30:15.761 -> [ 0.322156] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
19:30:15.761 -> [ 0.338688] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
19:30:15.761 -> [ 0.353734] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
19:30:15.794 -> [ 0.367649] TCP: Hash tables configured (established 1024 bind 1024)
19:30:15.794 -> [ 0.380372] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
19:30:15.826 -> [ 0.393222] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
19:30:15.826 -> [ 0.407306] NET: Registered protocol family 1
19:30:15.826 -> [ 0.415874] PCI: CLS 0 bytes, default 32
19:30:15.862 -> [ 0.431648] workingset: timestamp_bits=14 max_order=15 bucket_order=1
19:30:15.862 -> [ 0.450061] squashfs: version 4.0 (2009/01/31) Phillip Lougher
19:30:15.895 -> [ 0.461530] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) © 2001-2006 Red Hat, Inc.
19:30:15.895 -> [ 0.483127] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
19:30:15.930 -> [ 0.500428] mt7621_gpio 10000600.gpio: registering 32 gpios
19:30:15.930 -> [ 0.511701] mt7621_gpio 10000600.gpio: registering 32 gpios
19:30:15.962 -> [ 0.522960] mt7621_gpio 10000600.gpio: registering 32 gpios
19:30:15.962 -> [ 0.534245] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
19:30:15.962 -> [ 0.549946] printk: console [ttyS0] disabled
19:30:15.995 -> [ 0.558430] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
19:30:15.995 -> [ 0.576233] printk: console [ttyS0] enabled
19:30:16.029 -> [ 0.592726] printk: bootconsole [early0] disabled
19:30:16.029 -> [ 0.612163] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
19:30:16.063 -> [ 0.631263] spi-mt7621 10000b00.spi: sys_freq: 193333333
19:30:16.098 -> [ 0.663923] spi-nor spi0.0: w25q256 (32768 Kbytes)
19:30:16.098 -> [ 0.673565] 4 fixed-partitions partitions found on MTD device spi0.0
19:30:16.098 -> [ 0.686234] OF: Bad cell count for /palmbus@10000000/spi@b00/flash@0/partitions
19:30:16.132 -> [ 0.700753] OF: Bad cell count for /palmbus@10000000/spi@b00/flash@0/partitions
19:30:16.132 -> [ 0.715815] OF: Bad cell count for /palmbus@10000000/spi@b00/flash@0/partitions
19:30:16.166 -> [ 0.730378] OF: Bad cell count for /palmbus@10000000/spi@b00/flash@0/partitions
19:30:16.166 -> [ 0.745112] Creating 4 MTD partitions on “spi0.0”:
19:30:16.166 -> [ 0.754607] 0x000000000000-0x000000030000 : “u-boot”
19:30:16.200 -> [ 0.768297] 0x000000030000-0x000000040000 : “u-boot-env”
19:30:16.200 -> [ 0.780242] 0x000000040000-0x000000050000 : “factory”
19:30:16.234 -> [ 0.793554] 0x000000050000-0x000002000000 : “firmware”
19:30:16.234 -> [ 0.805441] 2 uimage-fw partitions found on MTD device firmware
19:30:16.234 -> [ 0.817247] Creating 2 MTD partitions on “firmware”:
19:30:16.234 -> [ 0.827092] 0x000000000000-0x00000021b3fa : “kernel”
19:30:16.269 -> [ 0.836926] mtd: partition “kernel” doesn’t end on an erase/write block – force read-only
19:30:16.269 -> [ 0.856519] 0x00000021b3fa-0x000001fb0000 : “rootfs”
19:30:16.305 -> [ 0.866452] mtd: partition “rootfs” doesn’t start on an erase/write block boundary – force read-only
19:30:16.305 -> [ 0.886885] mtd: setting mtd5 (rootfs) as root device
19:30:16.305 -> [ 0.897103] 1 squashfs-split partitions found on MTD device rootfs
19:30:16.339 -> [ 0.909384] 0x000000590000-0x000001fb0000 : “rootfs_data”
19:30:16.408 -> [ 0.972898] rt3050-esw 10110000.esw: mediatek esw at 0xb0110000, irq 25 initialized
19:30:16.408 -> [ 0.989058] mtk_soc_eth 10100000.ethernet eth0: mediatek frame engine at 0xb0100000, irq 5
19:30:16.441 -> [ 1.007586] NET: Registered protocol family 10
19:30:16.441 -> [ 1.022590] Segment Routing with IPv6
19:30:16.441 -> [ 1.030087] NET: Registered protocol family 17
19:30:16.474 -> [ 1.039048] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
19:30:16.474 -> [ 1.064736] 8021q: 802.1Q VLAN Support v1.8
19:30:16.505 -> [ 1.088613] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
19:30:16.539 -> [ 1.109696] Freeing unused kernel memory: 1228K
19:30:16.539 -> [ 1.118701] This architecture does not have kernel memory protection.
19:30:16.539 -> [ 1.131471] Run /sbin/init as init process
19:30:17.735 -> [ 2.298329] init: Console is alive
19:30:17.735 -> [ 2.305793] init: - watchdog -
19:30:19.354 -> [ 3.914523] kmodloader: loading kernel modules from /etc/modules-boot.d/*
19:30:19.516 -> [ 4.099001] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
19:30:19.561 -> [ 4.124041] init: - preinit -
19:30:19.987 -> [ 4.559074] rt3050-esw 10110000.esw: port 0 link up
19:30:21.420 -> [ 6.005715] random: jshn: uninitialized urandom read (4 bytes read)
19:30:21.546 -> [ 6.134097] random: jshn: uninitialized urandom read (4 bytes read)
19:30:21.859 -> [ 6.438773] random: jshn: uninitialized urandom read (4 bytes read)
19:30:22.623 -> [ 7.192829] rt3050-esw 10110000.esw: port 0 link down
19:30:22.924 -> Press the [f] key and hit [enter] to enter fails[ 7.517002] random: procd: uninitialized urandom read (4 bytes read)
19:30:22.970 -> afe mode
19:30:22.970 -> Press the [1], [2], [3] or [4] key and hit [enter] to select the debug level
19:30:26.192 -> [ 10.762687] rt3050-esw 10110000.esw: port 0 link up
19:30:26.192 -> [ 10.772427] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
19:30:26.234 -> [ 10.785453] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
19:30:27.430 -> [ 12.006905] jffs2_scan_eraseblock(): End of filesystem marker found at 0x10000
19:30:27.430 -> [ 12.021375] jffs2_build_filesystem(): unlocking the mtd device…
19:30:27.474 -> [ 12.021381] done.
19:30:36.298 -> ^@�^@�߿̠^@^@^@^Xx^@^@�$^@^L&� �^F^@!0^A^@^@^@^@�[ 12.041088] jffs2_build_filesystem(): erasing all blocks after the end marker…
19:34:52.634 -> [ 101.677401] done.
19:34:52.634 -> [ 101.696092] jffs2: notice: (402) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
19:34:52.669 -> [ 101.728762] mount_root: overlay filesystem has not been fully initialized yet
19:34:52.669 -> [ 101.752446] mount_root: switching to jffs2 overlay
19:34:52.704 -> [ 101.766147] overlayfs: upper fs does not support tmpfile.
19:34:52.704 -> - config restore -
19:34:53.518 -> [ 102.601635] urandom-seed: Seed file not found (/etc/urandom.seed)
19:34:53.739 -> [ 102.802144] procd: - early -
19:34:53.739 -> [ 102.808438] procd: - watchdog -
19:34:54.546 -> [ 103.630512] procd: - watchdog -
19:34:54.578 -> [ 103.637315] procd: - ubus -
19:34:54.726 -> [ 103.792866] random: ubusd: uninitialized urandom read (4 bytes read)
19:34:54.726 -> [ 103.809091] random: ubusd: uninitialized urandom read (4 bytes read)
19:34:54.765 -> [ 103.832243] random: ubusd: uninitialized urandom read (4 bytes read)
19:34:54.797 -> [ 103.856248] procd: - init -
19:35:20.707 ->
19:35:20.707 -> BusyBox v1.35.0 (2023-04-27 20:28:15 UTC) built-in shell (ash)
19:35:20.707 ->
19:35:21.028 -> _______ ________ __
19:35:21.028 -> | |.-----.-----.-----.| | | |.----.| |
19:35:21.028 -> | - || _ | -| || | | || || |
19:35:21.061 -> |
_____|| |
||||___||| |____|
19:35:21.061 -> |
| W I R E L E S S F R E E D O M
19:35:21.061 -> -----------------------------------------------------
19:35:21.061 -> OpenWrt 22.03.5, r20134-5f15225c1e
19:35:21.101 -> -----------------------------------------------------
19:35:21.196 -> root@OpenWrt:/# [ 133.983592] br-lan: port 1(eth0.1) entered blocking state
19:35:24.917 -> [ 133.994396] br-lan: port 1(eth0.1) entered disabled state
19:35:24.917 -> [ 134.005703] device eth0.1 entered promiscuous mode
19:35:24.960 -> [ 134.015262] device eth0 entered promiscuous mode
19:35:25.052 -> [ 134.094359] br-lan: port 1(eth0.1) entered blocking state
19:35:25.052 -> [ 134.105139] br-lan: port 1(eth0.1) entered forwarding state
19:35:25.958 -> [ 135.035388] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
19:36:59.422 -> rm -rf init_M7603* && wget http://minerback.heltec.cn/download/r
19:36:59.422 -> eset_M7603.sh && chmod +x reset_M7603.sh && ./reset_M7603.sh EU868
19:36:59.579 -> Downloading ‘http://minerback.heltec.cn/download/reset_M7603.sh’
19:37:00.814 -> Connecting to 47.243.108.19:80
19:37:01.485 -> Writing to ‘reset_M7603.sh’
19:37:01.517 ->
reset_M7603.sh 100% || 1804 0:00:00 ETA
19:37:01.517 -> Download completed (1804 bytes)
19:37:01.549 -> rm: can’t remove ‘HT-M7603_V1_2.tar.gz’: No such file or directory
19:37:01.595 -> Downloading ‘http://minerback.heltec.cn/download/HT-M7603_V1_2.tar.gz’
19:37:02.199 -> Connecting to 47.243.108.19:80
19:37:02.869 -> Writing to ‘HT-M7603_V1_2.tar.gz’
19:37:03.857 ->
HT-M7603_V1_2.tar.gz 27% |******** | 96317 0:00:02 ETA
HT-M7603_V1_2.tar.gz 100% |
| 344k 0:00:00 ETA
19:37:04.283 -> Download completed (352706 bytes)
19:37:04.283 -> HT-M7603/
19:37:04.283 -> HT-M7603/lrgateway
19:37:04.283 -> HT-M7603/lora/
19:37:04.283 -> HT-M7603/lora/lrgateway
19:37:04.327 -> HT-M7603/lora/global_conf_EU868.json
19:37:04.327 -> HT-M7603/lora/global_conf_KR920.json
19:37:04.327 -> HT-M7603/lora/global_conf_AS923_1.json
19:37:04.327 -> HT-M7603/lora/lora_pkt_fwd_mqtt
19:37:04.358 -> HT-M7603/lora/global_conf.json
19:37:04.359 -> HT-M7603/lora/gwid
19:37:04.359 -> HT-M7603/lora/global_conf_CN470.json
19:37:04.395 -> HT-M7603/lora/update_gwid.sh
19:37:04.395 -> HT-M7603/lora/setting
19:37:04.395 -> HT-M7603/lora/global_conf_AS923_4.json
19:37:04.395 -> HT-M7603/lora/reset_lgw.sh
19:37:04.395 -> HT-M7603/lora/global_conf_AU915.json
19:37:04.395 -> HT-M7603/lora/null
19:37:04.434 -> HT-M7603/lora/global_conf_AS923_2.json
19:37:04.434 -> HT-M7603/lora/gpio.sh
19:37:04.434 -> HT-M7603/lora/lora_pkt_fwd
19:37:04.466 -> HT-M7603/lora/global_conf_AS923_1B.json
19:37:04.466 -> HT-M7603/lora/global_conf_US915.json
19:37:04.466 -> HT-M7603/lora/settings.toml
19:37:04.466 -> HT-M7603/lora/global_conf_IN865.json
19:37:04.466 -> HT-M7603/lora/global_conf_AS923_3.json
19:37:04.466 -> HT-M7603/lora/global_conf_RU864.json
19:37:04.500 -> HT-M7603/www/
19:37:04.500 -> HT-M7603/www/webcam/
19:37:04.500 -> HT-M7603/www/webcam/index.html
19:37:04.500 -> HT-M7603/www/webui.html
19:37:04.500 -> HT-M7603/www/css/
19:37:04.500 -> HT-M7603/www/css/bootstrap-select.min.css
19:37:04.500 -> HT-M7603/www/css/style.css
19:37:04.533 -> HT-M7603/www/css/bootstrap.min.css
19:37:04.533 -> HT-M7603/www/node_example.ino
19:37:04.533 -> HT-M7603/www/index.html
19:37:04.533 -> HT-M7603/www/js/
19:37:04.533 -> HT-M7603/www/js/jquery.min.js
19:37:04.533 -> HT-M7603/www/js/docs.min.js
19:37:04.566 -> HT-M7603/www/js/bootstrap.min.js
19:37:04.566 -> HT-M7603/www/js/bootstrap-select.min.js
19:37:04.566 -> HT-M7603/www/luci-static/
19:37:04.566 -> HT-M7603/www/luci-static/bootstrap/
19:37:04.566 -> HT-M7603/www/luci-static/bootstrap/mobile.css
19:37:04.566 -> HT-M7603/www/luci-static/bootstrap/cascade.css
19:37:04.599 -> HT-M7603/www/luci-static/bootstrap/favicon.ico
19:37:04.599 -> HT-M7603/www/luci-static/bootstrap/html5.js
19:37:04.599 -> HT-M7603/www/luci-static/resources/
19:37:04.599 -> HT-M7603/www/luci-static/resources/xhr.js
19:37:04.632 -> HT-M7603/www/luci-static/resources/wireless.svg
19:37:04.632 -> HT-M7603/www/luci-static/resources/cbi/
19:37:04.632 -> HT-M7603/www/luci-static/resources/cbi/help.gif
19:37:04.632 -> HT-M7603/www/luci-static/resources/cbi/apply.gif
19:37:04.665 -> HT-M7603/www/luci-static/resources/cbi/file.gif
19:37:04.665 -> HT-M7603/www/luci-static/resources/cbi/key.gif
19:37:04.665 -> HT-M7603/www/luci-static/resources/cbi/edit.gif
19:37:04.665 -> HT-M7603/www/luci-static/resources/cbi/down.gif
19:37:04.696 -> HT-M7603/www/luci-static/resources/cbi/reset.gif
19:37:04.696 -> HT-M7603/www/luci-static/resources/cbi/link.gif
19:37:04.696 -> HT-M7603/www/luci-static/resources/cbi/remove.gif
19:37:04.696 -> HT-M7603/www/luci-static/resources/cbi/save.gif
19:37:04.731 -> HT-M7603/www/luci-static/resources/cbi/download.gif
19:37:04.731 -> HT-M7603/www/luci-static/resources/cbi/arrow.gif
19:37:04.731 -> HT-M7603/www/luci-static/resources/cbi/user.gif
19:37:04.731 -> HT-M7603/www/luci-static/resources/cbi/add.gif
19:37:04.764 -> HT-M7603/www/luci-static/resources/cbi/fieldadd.gif
19:37:04.764 -> HT-M7603/www/luci-static/resources/cbi/up.gif
19:37:04.764 -> HT-M7603/www/luci-static/resources/cbi/folder.gif
19:37:04.764 -> HT-M7603/www/luci-static/resources/cbi/reload.gif
19:37:04.797 -> HT-M7603/www/luci-static/resources/cbi/find.gif
19:37:04.797 -> HT-M7603/www/luci-static/resources/bandwidth.svg
19:37:04.797 -> HT-M7603/www/luci-static/resources/icons/
19:37:04.830 -> HT-M7603/www/luci-static/resources/icons/port_up.png
19:37:04.830 -> HT-M7603/www/luci-static/resources/icons/loading.gif
19:37:04.830 -> HT-M7603/www/luci-static/resources/icons/signal-0-25.png
19:37:04.830 -> HT-M7603/www/luci-static/resources/icons/port_down.png
19:37:04.863 -> HT-M7603/www/luci-static/resources/icons/wifi_big_disabled.png
19:37:04.863 -> HT-M7603/www/luci-static/resources/icons/switch_disabled.png
19:37:04.863 -> HT-M7603/www/luci-static/resources/icons/signal-50-75.png
19:37:04.896 -> HT-M7603/www/luci-static/resources/icons/ethernet_disabled.png
19:37:04.896 -> HT-M7603/www/luci-static/resources/icons/wifi.png
19:37:04.896 -> HT-M7603/www/luci-static/resources/icons/encryption.png
19:37:04.929 -> HT-M7603/www/luci-static/resources/icons/ethernet.png
19:37:04.929 -> HT-M7603/www/luci-static/resources/icons/wifi_big.png
19:37:04.929 -> HT-M7603/www/luci-static/resources/icons/signal-0.png
19:37:04.929 -> HT-M7603/www/luci-static/resources/icons/vlan.png
19:37:04.962 -> HT-M7603/www/luci-static/resources/icons/bridge_disabled.png
19:37:04.962 -> HT-M7603/www/luci-static/resources/icons/signal-none.png
19:37:04.962 -> HT-M7603/www/luci-static/resources/icons/encryption_disabled.png
19:37:04.995 -> HT-M7603/www/luci-static/resources/icons/tunnel.png
19:37:04.995 -> HT-M7603/www/luci-static/resources/icons/signal-75-100.png
19:37:04.995 -> HT-M7603/www/luci-static/resources/icons/vlan_disabled.png
19:37:05.028 -> HT-M7603/www/luci-static/resources/icons/signal-25-50.png
19:37:05.028 -> HT-M7603/www/luci-static/resources/icons/wifi_disabled.png
19:37:05.028 -> HT-M7603/www/luci-static/resources/icons/tunnel_disabled.png
19:37:05.028 -> HT-M7603/www/luci-static/resources/icons/switch.png
19:37:05.061 -> HT-M7603/www/luci-static/resources/icons/bridge.png
19:37:05.061 -> HT-M7603/www/luci-static/resources/load.svg
19:37:05.061 -> HT-M7603/www/luci-static/resources/cbi.js
19:37:05.061 -> HT-M7603/www/luci-static/resources/connections.svg
19:37:05.094 -> HT-M7603/www/luci-static/resources/wifirate.svg
19:37:05.094 -> HT-M7603/www/cgi-bin/
19:37:05.094 -> HT-M7603/www/cgi-bin/diswifi
19:37:05.094 -> HT-M7603/www/cgi-bin/luci
19:37:05.094 -> HT-M7603/www/cgi-bin/getinfo
19:37:05.127 -> HT-M7603/www/cgi-bin/setwifi
19:37:05.127 -> HT-M7603/www/cgi-bin/setpass
19:37:05.127 -> HT-M7603/www/cgi-bin/addgateway
19:37:05.127 -> HT-M7603/www/cgi-bin/checkwifi
19:37:05.127 -> HT-M7603/www/cgi-bin/cgi-download
19:37:05.127 -> HT-M7603/www/cgi-bin/cgi-upload
19:37:05.160 -> HT-M7603/www/cgi-bin/setgateway
19:37:05.160 -> HT-M7603/www/cgi-bin/restartServer
19:37:05.160 -> HT-M7603/www/cgi-bin/genQR
19:37:05.160 -> HT-M7603/www/cgi-bin/switchregion
19:37:05.160 -> HT-M7603/www/cgi-bin/aps
19:37:05.160 -> HT-M7603/www/cgi-bin/get_latest_firmware
19:37:05.193 -> HT-M7603/www/cgi-bin/set
19:37:05.193 -> HT-M7603/www/cgi-bin/getssid
19:37:05.193 -> HT-M7603/index.htm
19:37:05.193 -> HT-M7603/service/
19:37:05.193 -> HT-M7603/service/clearlog
19:37:05.193 -> HT-M7603/service/updateServer
19:37:05.193 -> HT-M7603/service/checkstatus
19:37:05.234 -> HT-M7603/service/rgb
19:37:11.497 -> ./reset_M7603.sh: line 18: /etc/init.d/helium_gateway: not found
19:37:11.497 -> ./reset_M7603.sh: line 19: /etc/init.d/helium_gateway: not found
19:37:11.497 -> ./reset_M7603.sh: line 20: /etc/init.d/checkstat: not found
19:37:11.592 -> Not running
19:37:11.628 -> insmod custom gpio based spi
19:37:11.628 -> Failed to find spi-gpio-custom. Maybe it is a built in module ?
19:37:11.670 -> update gateway id
19:37:11.748 -> 60F 40
19:37:11.783 -> Gateway_ID set to 40D63CF8851231 in file /lora/global_conf.json
19:37:11.820 -> Starting lora_pkt_fwd
19:37:11.820 -> /etc/rc.common: line 39: /lora/lora_pkt_fwd: not found
19:37:11.853 -> Unable to start, see /tmp/lora_pkt_fwd.log
19:37:11.853 -> ./reset_M7603.sh: line 22: /etc/init.d/usrlog: not found
19:37:11.853 -> ./reset_M7603.sh: line 23: /etc/init.d/update: not found
19:37:11.853 -> ./reset_M7603.sh: line 24: /etc/init.d/update: not found
19:37:12.159 -> Not running
19:37:13.245 -> Not running
19:37:13.278 -> insmod custom gpio based spi
19:37:13.278 -> Failed to find spi-gpio-custom. Maybe it is a built in module ?
19:37:13.323 -> update gateway id
19:37:13.402 -> AA555A000767000 40
19:37:13.434 -> Gateway_ID set to 434 in file /lora/global_conf.json
19:37:13.472 -> Starting lora_pkt_fwd
19:37:13.472 -> /etc/rc.common: line 39: /lora/lora_pkt_fwd: not found
19:37:13.511 -> Unable to start, see /tmp/lora_pkt_fwd.log
19:37:13.511 -> EU868
19:37:13.511 -> Changing password for root
19:37:13.511 -> New password:
19:37:13.511 -> Retype password:
19:37:13.544 -> passwd: password for root changed by root
19:37:13.544 -> uci: Invalid argument
19:37:13.575 -> {“result”=“success”,“message”=“operation finished”}
19:37:13.767 -> root@OpenWrt:/# �
> Blockquote
Hello everybody,
I found a way to fix missing MQTT when flashing a firmware with command given by richard3366. He was right with a command but problem is, that script flashes new version 1.6 which does not show MQTT. What you have to do is change name of script to reset_M7603.sh to reset_M7603_V105.sh. That is
rm -rf init_M7603* && wget http://minerback.heltec.cn/download/reset_M7603_V105.sh && chmod +x reset_M7603_V105.sh && ./reset_M7603_V105.sh EU868
scripts are on http://minerback.heltec.cn/download/
and you will get back missing MQTT :slight_smile: yeeeey
Have a nice day
