Heltec wireless tracker problem flashing
Hi my Wireless Tracker does not allow me to flash any code to it. It keeps rebooting. Here is the error message
22:09:20.859 -> Rebooting…
22:09:20.859 -> ESP-ROM:esp32s3-20210327
22:09:20.859 -> Build:Mar 27 2021
22:09:20.859 -> rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
22:09:20.859 -> Saved PC:0x40379e9a
22:09:20.859 -> SPIWP:0xee
22:09:20.859 -> mode:DIO, clock div:1
22:09:20.859 -> load:0x3fce2820,len:0x1180
22:09:20.859 -> load:0x403c8700,len:0xc2c
22:09:20.859 -> load:0x403cb700,len:0x311c
22:09:20.904 -> entry 0x403c88b8
22:09:22.161 -> Guru Meditation Error: Core 1 panic’ed (Cache error).
22:09:22.161 -> Dbus write to cache rejected, error address: 0x3c04163c
22:09:22.161 ->
22:09:22.161 -> Core 1 register dump:
22:09:22.161 -> PC : 0x40056f08 PS : 0x00060734 A0 : 0x82010814 A1 : 0x3fcebf10
22:09:22.161 -> A2 : 0x3c04163d A3 : 0x3fcebf22 A4 : 0x00000003 A5 : 0x3c04163f
22:09:22.161 -> A6 : 0x00000000 A7 : 0x0000002c A8 : 0x40000000 A9 : 0x3fcebf10
22:09:22.161 -> A10 : 0x00060723 A11 : 0x00000001 A12 : 0x00060720 A13 : 0x00060723
22:09:22.161 -> A14 : 0x3fca29b0 A15 : 0x0000abab SAR : 0x00000008 EXCCAUSE: 0x00000007
22:09:22.161 -> EXCVADDR: 0x00000000 LBEG : 0x40056f08 LEND : 0x40056f12 LCOUNT : 0x00000000
22:09:22.161 ->
22:09:22.161 ->
22:09:22.161 -> Backtrace: 0x40056f05:0x3fcebf10 0x42010811:0x3fcebf20 0x42011181:0x3fcebf80 0x4200b0c7:0x3fcebfa0 0x4200b0e2:0x3fcebfc0 0x4200326d:0x3fcebfe0 0x42003289:0x3fcec000 0x420033ab:0x3fcec020 0x4200291c:0x3fcec040 0x42012a05:0x3fcec070 0x4037dc5d:0x3fcec090
22:09:22.161 ->
22:09:22.161 ->
22:09:22.161 ->
22:09:22.161 ->
22:09:22.161 -> ELF file SHA256: 75d9bd566
22:09:22.161 ->
22:09:22.161 -> Rebooting…
when i try to flash the GPS or OLED display sample code to the device it gives me an error
“A fatal error occurred: Could not open COM4, the port doesn’t exist
Failed uploading: uploading error: exit status 2”
I have read and tried pressing User and Reset buttons while powering up allow it to go into programming mode but this has not helped.
Has anyone encountered this and was it fixable?
PLEASE HELP
Hi Songtran71,
I had the same issue and found the solution in the FAQ, i had to try several times, 2-3 times, but i worked:
“How to access boot mode manually(Unable to upload code)”
https://docs.heltec.cn/en/node/esp32/wireless_tracker/frequently_asked_questions.html
/Jan
Hi There,
I finally got some replies from Heltec support, they said that there might have been problems with some models in the last library release.
They recommended me to update to 2.1.5
This FIXED the problem!!!
I can’t believe no one else had this problem and replied to the post
Anyway, life goes on again… thanks for your message
