Hi, i am currently trying to connect the wireless tracker to nearby gateway. Unfortunately the nearest gateway is a few kilometres away. I am unable to connect to any gateway. I am using the default example for LoraWan
Not sure if i can :
- increase the tx power
- increase the spreading factor
- or modify the datarate so it can send further
if that’s okay, anyone can show me how to change those parameters?
below is the partial debug output from the wireless tracker
Debug Output :
08:10:20.082 -> RX on freq 923200000 Hz at DR 2
08:10:20.160 -> Event : Rx Timeout
08:10:20.724 -> TX on freq 923400000 Hz at DR 2
08:10:21.098 -> Event : Tx Done
08:10:26.074 -> RX on freq 923400000 Hz at DR 2
08:10:26.167 -> Event : Rx Timeout
08:10:27.088 -> RX on freq 923200000 Hz at DR 2
08:10:27.165 -> Event : Rx Timeout
08:10:27.714 -> TX on freq 923200000 Hz at DR 2
08:10:28.122 -> Event : Tx Done
08:10:33.098 -> RX on freq 923200000 Hz at DR 2
08:10:33.176 -> Event : Rx Timeout
08:10:34.097 -> RX on freq 923200000 Hz at DR 2
08:10:34.174 -> Event : Rx Timeout
08:10:34.721 -> TX on freq 923200000 Hz at DR 2
08:10:35.126 -> Event : Tx Done
08:10:40.109 -> RX on freq 923200000 Hz at DR 2
