My heltec wireless tracker suddenly does not boot anymore when powered via USB-C connector or 5 V VDD pin.
I tried to power it with 3.7V via battery connector. -> Success, device boots.
Perhaps, an over-voltage of the powerbank or static electricity charge caused an electronic part to fail.
Now I’m searching for the problem in the 5V part of the PCB.
I looked at the schematic.
Possible causes (imho), because they are connected at the 5V line: defect of
a) TP4054 chip
b) D1
c) R1
d) C1
Fail of Fuse F1 is unlikely to have failed, because I tried to power with 5V via pin 1 of header 8.
R2 is irrelevant because it controls the transistor which switches off the line back to the battery from voltage coming via D2 (usb or 5V); battery charging is controlled by TP4054.
My problem:
While the schematic diagram is good and the concept is understandable, I did not found a description of where to find the parts on the PCB.
-> I need to know: where on the PCB can I find D1, R1 and C1.
Position of F1, R2, D2 and Q1 would be also of interest.
TP4054 was easily to locate (stamped with synonym LTH7R).
- Thomas
