Hello,I am trying to set up communication with the Epever MPPT controller via Modbus. Unfortunately, with Heltec Wireless Stick V3 the communication does not work - on the serial port it says something like:
1~⸮226
I tried the same code on the ESP32 Wroom kit, where the communication works properly and I get data from the controller as:
PV Voltage:
0.00
PV Current:
0.00
Battery Voltage:
12.47
I am using MAX3485 converter, pins DE and RE_NEG are defined and wired the same. I have connected the RO and DI pins of the converter to the RX and TX pins of the Heltec Wireless Stick V3 board.
The connection of MAX3485 and Heltec WS is:
RO -> RX (GPIO 44)
RE| -> 46
DE -> 45
DI -> TX (GPIO 43)
The registers are definitely defined correctly, so the problem must be in the communication between Wireless Stick and converter for RS485.
I also tried the Heltec WiFi LoRa32 V3 board, and it still didn’t work.
I am attaching the code that works for the ESP32 Wroom kit:
#include <ModbusMaster.h>
#define MAX485_DE 4
#define MAX485_RE_NEG 2
ModbusMaster node;
void preTransmission()
digitalWrite(MAX485_RE_NEG, 1);
digitalWrite(MAX485_DE, 1);
void postTransmission()
digitalWrite(MAX485_RE_NEG, 0);
digitalWrite(MAX485_DE, 0);
void setup()
pinMode(MAX485_RE_NEG, OUTPUT);
pinMode(MAX485_DE, OUTPUT);
// Init in receive mode
// Modbus communication runs at 115200 baud
//Modbus slave ID 1
node.begin(1, Serial);
// Callbacks allow us to configure the RS485 transceiver correctly
node.preTransmission(preTransmission);
node.postTransmission(postTransmission);
Serial.println("test");
uint8_t resultMain;
resultMain = node.readInputRegisters(0x3100, 6);
if (resultMain == node.ku8MBSuccess)
Serial.println(" - - - - - - - - ");
Serial.println("PV Voltage: ");
Serial.println(node.getResponseBuffer(0x00) / 100.0f);
Serial.println("PV Current: ");
Serial.println(node.getResponseBuffer(0x01) / 100.0f);
Serial.println("Battery Voltage: ");
Serial.println(node.getResponseBuffer(0x04) / 100.0f);
Serial.println("Battery Charge Current: ");
Serial.println(node.getResponseBuffer(0x05) / 100.0f);
Could you please help me find out where the problem is?
