Well, there you go. That’s what mine look like, although mine don’t have V2 anywhere on them. There were obvious changes between the different WiFi LoRa 32 boards (V1, V2 & V3), and internal changes been the V2 and ‘V2.1’ boards, but I’ve never seen a WSL pinout diagram labelled “V2” or any mention of changes between the board illustrated and one that has “V2” on it. So who knows what’s going on there… The WiFi LoRa 32 V2.1 board was a bit of a ‘stealth’ release, with no ‘fanfare’ on Heltec’s part and no obvious physical difference between it and the V2 board (it was also just labelled “V2”), but internally some processor GPIOs were used differently, which caused a bit of a problem for some users.
That doesn’t sound like the sort of thing you’e seeing, but who knows… Do you recall whether or not your earlier board also had the “V2” on it, or is it just that it looked the same? (My boards look exactly the same as the ones in the link you provided, but I don’t see “V2” on either those or mine).
