Heltec wireless stick lite - deep sleep
I’m looking for a method to save the needed states into RTC memory, so that after deep sleep the device will send again sensor data,
Want to create a LoraWAN sensor with deep sleeping mode, but after wakeup the device will not send any message more.
DeviceState (eDeviceState_LoraWan) is 2 (so joined as far as I understand) but something is missing - was “lost” while deep sleep…
Is there a ready procedure for save to / restore from RTC memory - or what I need to save for get it work?
Same question (if different) for Wifi Lora32 (V3) …
Or maybe - somebody have a working example (Arduino-) code for a sleeping sensor?
Thanks for any suggestion!
Michael
in the meantime I have tried to use the LoraWAN example code (from Arduino examples).
Here will be used:
  switch( deviceState )
    case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
    case DEVICE_STATE_JOIN:
      LoRaWAN.join();
    case DEVICE_STATE_SEND:
      prepareTxFrame( appPort );
      LoRaWAN.send();
    case DEVICE_STATE_CYCLE:
    case DEVICE_STATE_SLEEP:
      LoRaWAN.sleep(loraWanClass);
I want to use between the send cycles a real deep sleep (low power).
With LoRaWAN.sleep the device take about 900uA - with optimized deep sleep about 22uA.
How can I change this in the procedure?
LORAWAN.sleep seems be ok between all other states, but after finish with sending packet need to use other sleep procedure.
Thanks!
Michael
