Heltec wireless stick & DRAGINO
Hello everybody,
I am trying to configure the communication between Heltec Wireless Stick & Dragino Lg01-N but I cannot produce a script on Arduino Ide to be able to send a single number. I entered all the correct information in Dragino but I don’t know how to do the script on the Wireless Stick. Have any of you tried this data sending?
How can I enter the information of:
  • channel id
  • node id
    My test script is:
#include “heltec.h”
#define BAND 433E6 //you can set band here directly,e.g. 868E6,915E6
int counter = 0;
void setup()
Heltec.begin(true /DisplayEnable Enable/, true /Heltec.LoRa Disable/, true /Serial Enable/, true /PABOOST Enable/, BAND /long BAND/);
Serial.print("Sending packet: ");
Serial.println(counter);
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.print(counter);
LoRa.endPacket();
counter++;
Thanks a lot.
Marco
Please refer to: https://heltec-automation-docs.readthedocs.io/en/latest/esp32/lorawan/index.html
