Hello, I’m using Heltec WiFi LoRa32 (V3) boards (ESP32+SX1262).
I have this code that works for waking up from light-sleep mode by receiving any LoRa packet that is subsequently processed. However, I would need to be able to also take measurements and send the measurements at regular intervals. I have already tried something (commented in the code), however it does not work properly.
Could you please advise me how to make the measurements at regular intervals also work together with the above program for the LoRa repeater?
Thank you
#include <Arduino.h>
#include "LoRaWan_APP.h"
#include <Wire.h>
#include "HT_SSD1306Wire.h"
#include "Adafruit_SHT31.h"
#include <RTClib.h>
#include "esp_timer.h"
#include "esp_adc_cal.h"
String packet;
String lastChar;
String payload_string;
String topic;
String id_src;
String id_dst;
esp_sleep_wakeup_cause_t wakeup_reason;
static void oneshot_timer_callback(void* arg);
static void periodic_timer_callback(void* arg);
esp_timer_handle_t oneshot_timer;
volatile bool timerActive = false;
#define TX_OUTPUT_POWER 10 // dBm
// 1: 250 kHz,
// 2: 500 kHz,
// 3: Reserved]
#define LORA_SPREADING_FACTOR 10 // [SF7..SF12]
// 2: 4/6,
// 3: 4/7,
// 4: 4/8]
#define RX_TIMEOUT_VALUE 3000
#define BUFFER_SIZE 100 // Define the payload size here
char txpacket[BUFFER_SIZE];
char rxpacket[BUFFER_SIZE];
/** LoRa transmit success */
void OnTxDone(void);
/** LoRa receive success */
void OnRxDone(uint8_t *payload, uint16_t size, int16_t rssi, int8_t snr);
/** LoRa transmit timeout */
void OnTxTimeout(void);
/** LoRa receive timeout */
void OnRxTimeout(void);
int16_t txNumber;
int16_t rssi,rxSize;
bool lora_idle = true;
#define uS_TO_S_FACTOR 1000000
uint16_t originalTimeToSleep = 16;
uint16_t timeToSleep = originalTimeToSleep;
RTC_DATA_ATTR uint64_t rtc_counter1 = 0;
uint64_t rtc_offset = 0;
void VextON(void)
pinMode(Vext,OUTPUT);
digitalWrite(Vext, LOW);
digitalWrite(Vext, HIGH);
void print_wakeup_reason(){
wakeup_reason = esp_sleep_get_wakeup_cause();
switch(wakeup_reason){
case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
void goToSleep(void)
// Go back to bed
Serial.println("Start sleeping");
Serial.flush();
pinMode(12, INPUT_PULLUP);
esp_sleep_enable_ext0_wakeup(GPIO_NUM_14, RISING);
// Finally set ESP32 into sleep
//esp_sleep_enable_timer_wakeup(timeToSleep * uS_TO_S_FACTOR);
digitalWrite(LED, LOW);
esp_light_sleep_start();
// Begin serial communication
Mcu.begin();
pinMode(LED,OUTPUT);
print_wakeup_reason();
//rtc_offset = time(NULL) - rtc_counter1;
Wire.begin(SDA_OLED, SCL_OLED);
Wire1.begin(19,20);
RadioEvents.RxTimeout = OnRxTimeout;
Radio.Init( &RadioEvents );
Radio.Rx(0);
Radio.IrqProcess( );
if(lora_idle)
lora_idle = false;
Radio.Rx(0);
if(wakeup_reason == ESP_SLEEP_WAKEUP_TIMER)
//Serial.println("WAKEUP TIMER!");
measure();
Serial.flush();
goToSleep();
digitalWrite(LED, HIGH);
Serial.println ("RECEIVED!");
rssi=rssi;
rxSize=size;
rxpacket[size]='\0';
//Radio.Sleep( );
Serial.printf("\r\nreceived packet \"%s\" with rssi %d , length %d\r\n",rxpacket,rssi,rxSize);
lora_idle = true;
if(lora_idle == true)
Serial.printf("\r\nsending packet \"%s\" , length %d\r\n",rxpacket, strlen(rxpacket));
Radio.Send( (uint8_t *)rxpacket, strlen(rxpacket) ); //send the package out
lora_idle = false;
goToSleep();
Serial.println("Receive timeout");
// LoRa RX failed, go back to bed
void OnTxDone( void )
Serial.print("TX done......");
lora_idle = true;
void OnTxTimeout( void )
Radio.Sleep( );
Serial.print("TX Timeout......");
