Hi everyone, I am creating the weather station project based on Heltec Wifi Lora 32(version3.1) with SCD40 temperature,humidity and CO2 sensor. After uploading my code and connecting it to the TTN, it only sends uplink once. After that, it only receives downlink and can not send the uplink again.
Here is code:
#include “LoRaWan_APP.h”
#include <Wire.h>
#include “Adafruit_SCD30.h”
// SCD30 instance
Adafruit_SCD30 scd30;
/* OTAA parameters (your end device credentials) */
uint8_t devEui[] = { *****************};
uint8_t appEui[] = { **************************** };
uint8_t appKey[] = { ************************************* };
/* ABP parameters (not used in OTAA mode, but kept for reference) */
uint8_t nwkSKey[] = { 0x15, 0xB1, 0xD0, 0xEF, 0xA4, 0x63, 0xDF, 0xBE, 0x3D, 0x11, 0x18, 0x1E, 0x1E, 0xC7, 0xDA, 0x85 };
uint8_t appSKey[] = { 0xD7, 0x2C, 0x78, 0x75, 0x8C, 0xDC, 0xCA, 0xBF, 0x55, 0xEE, 0x4A, 0x77, 0x8D, 0x16, 0xEF, 0x67 };
uint32_t devAddr = (uint32_t)0x007E6AE1;
/* LoRaWAN channel mask */
uint16_t userChannelsMask[6] = { 0x00FF, 0x0000, 0x0000, 0x0000, 0x0000, 0x0000 };
/* LoRaWAN region, select in Arduino IDE tools */
/* LoRaWAN class, Class A and Class C are supported */
/* Application data transmission duty cycle (value in ms) */
/* OTAA activation */
/* Adaptive data rate (ADR) enable */
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
/* Number of trials to transmit the frame */
static void prepareTxFrame(uint8_t port)
if (scd30.dataReady())
if (!scd30.read())
Serial.println("Failed to read data from SCD30!");
return;
// Convert float values to integers for transmission
uint16_t co2_int = (uint16_t)scd30.CO2; // CO2 in ppm
uint16_t temp_int = (uint16_t)(scd30.temperature * 10); // Temp in 0.1°C
uint16_t hum_int = (uint16_t)(scd30.relative_humidity * 10); // Humidity in 0.1%
// Prepare LoRaWAN payload
appDataSize = 6;
appData[0] = (co2_int >> 8) & 0xFF;
appData[1] = co2_int & 0xFF;
appData[2] = (temp_int >> 8) & 0xFF;
appData[3] = temp_int & 0xFF;
appData[4] = (hum_int >> 8) & 0xFF;
appData[5] = hum_int & 0xFF;
Serial.print("CO2: ");
Serial.print(scd30.CO2);
Serial.print(" ppm, Temp: ");
Serial.print(scd30.temperature);
Serial.print(" °C, Humidity: ");
Serial.print(scd30.relative_humidity);
Serial.println(" %");
else
Serial.println("SCD30 data not ready.");
// Initialize I2C for SCD30
Wire.begin(41, 42); // SDA = 41, SCL = 42
// Initialize the SCD30 sensor
if (!scd30.begin())
Serial.println("Failed to initialize SCD30! Check wiring.");
while (1);
Serial.println("SCD30 initialized successfully.");
// LoRaWAN initialization
switch (deviceState)
case DEVICE_STATE_INIT:
#if (LORAWAN_DEVEUI_AUTO)
LoRaWAN.setDefaultDR(3);
case DEVICE_STATE_JOIN:
LoRaWAN.join();
case DEVICE_STATE_SEND:
prepareTxFrame(appPort);
LoRaWAN.send();
case DEVICE_STATE_CYCLE:
txDutyCycleTime = appTxDutyCycle + randr(-APP_TX_DUTYCYCLE_RND, APP_TX_DUTYCYCLE_RND);
case DEVICE_STATE_SLEEP:
LoRaWAN.sleep(loraWanClass);
And this is the output from serial monitor in Arduino IDE:
