Thanks again @Supporter.
Do you know where I can find a LiPo battery spec to use with this module? I searched around tech specs but I couldn’t find it.
Also, do you know if battery in the following link can be used in this module? https://produto.mercadolivre.com.br/MLB-1166773676-bateria-de-lipo-37v-1100mah-lithium-polimero-recarregavel-_JM?quantity=1#reco_item_pos=0&reco_backend=machinalis-seller-items&reco_backend_type=low_level&reco_client=vip-seller_items-above&reco_id=4098db9d-b2a2-4902-9b99-028516e2d49f
Best Regards,
Pedro Bertoleti
