Heltec WiFi LoRa 32 (V4) deep sleep current waveform
I’m playing with the (almost) new Heltec WiFi LoRa 32 (V4).
I had performed a measure (by means of Nordic PPK2) of the module when the ESP32-S3 is in Deep Sleep mode and also the radio SX 1262 is in Sleep Mode.
I found this strange current waveform:
I don’t understand these 300 uA peaks, any ideas ?
(note that the same peaks are present also when I enable Rx DutyCycle of the radio, mixed with the right waveform of the Rx Duty Cycle)
My going-to-sleep procedure (Arduino, Heltec libraries) is the following:
// target: to perform a measure (by means of Nordic PPK2) of a Heltec WiFi LoRa (V4)
// with the ESP32-S3 in Deep Sleep and also the radio SX 1262 in Sleep Mode
// going to sleep without any wakeup clause specified, only reset will exit from deep sleep
void go_to_sleep () {
ledOFF(); // GPIO_NUM_35
VextOFF(); // GPIO_NUM_36
Radio.Sleep();
// if RADIO_NSS = GPIO_NUM_8 goes LOW, Sleep Mode exits
pinMode (RADIO_NSS, OUTPUT);
digitalWrite (RADIO_NSS, HIGH);
gpio_hold_en (GPIO_NUM_8);
Serial.println (“GOING TO SLEEP NOW”);
Serial.flush();
// no wakeup clause specified, only reset will exit from deep sleep
esp_deep_sleep_start();
Serial.println (“This will never be printed”);
Thank you in advance for your kind attention
Did you also turn of the amplifier with vfem_ctrl? (GPIO7)
Hi Bart,
I followed your indication and my software now turns off the amplifier. Now all is okay: the current peaks disappeared and I measure a fantastic 13 uA in deep sleep, thank you !
Hi @aldesa
Could you hint how you got that low? Whatever I do I can’t get below 8mA in deep sleep. I tried so much but no way to get lower then 8mA. I already start to believe the board has an issue.
What exact libraries you are using?
running the following on a Heltec WiFi LoRa32 (V3)
// Heltek LoRa V3 LoRaWAN test - transmits packet every 60 seconds then sleeps
// ERRORS in library
// http://community.heltec.cn/t/solved-heltec-lora-v3-compiler-time-errors/18877
//edited sx126x.c line 9 replaced “ with ", i.e. #include “Arduino.h“ with #include “Arduino.h”
//edited sx1262-board.c retyped … in line 34 extern void lora_printf(const char *format, …);
// see https://github.com/HelTecAutomation/Heltec_ESP32/blob/master/examples/LoRaWAN/LoRaWan/LoRaWan.ino
/* Heltec Automation LoRaWAN communication example
 * Function:
 * 1. Upload node data to the server using the standard LoRaWAN protocol.
 * Description:
 * 1. Communicate using LoRaWAN protocol.
 * HelTec AutoMation, Chengdu, China
 * 成都惠利特自动化科技有限公司
 * www.heltec.org
#include "LoRaWan_APP.h"
/* OTAA para*/
uint8_t devEui[] = {xxxxxxxxxxxxxxxx };
uint8_t appEui[] = {xxxxxxxxxxxxxxxxxxx };
uint8_t appKey[] = { yyyyyyyyyyyyyyyy };
/* ABP para*/
uint8_t nwkSKey[] = { zzzzzzzzzzzzzzzzzz };
uint8_t appSKey[] = {zzzzzzzzzzzzzzzzzzz };
uint32_t devAddr =  ( uint32_t )zzzzzz;
DeviceClass_t  loraWanClass = CLASS_A;
/*the application data transmission duty cycle.  value in [ms].*/
uint32_t appTxDutyCycle = 60000;
/*OTAA or ABP*/
/*ADR enable*/
bool loraWanAdr = true;
bool isTxConfirmed = true;
/* Application port */
uint8_t appPort = 2;
* to the following table:
* Transmission nb | Data Rate
* 1 (first)       | DR
* 2               | DR
* 3               | max(DR-1,0)
* 4               | max(DR-1,0)
* 5               | max(DR-2,0)
* 6               | max(DR-2,0)
* 7               | max(DR-3,0)
* 8               | max(DR-3,0)
    appDataSize = 4;
    appData[0]++;// = 0x00;
    appData[1] = 0x01;
    appData[2] = 0x02;
    appData[3] = 0x03;
    Serial.printf("Sending %d  ", appData[0]);
//if true, next uplink will add MOTE_MAC_DEVICE_TIME_REQ
  Mcu.begin(HELTEC_BOARD,SLOW_CLK_TPYE);
  switch( deviceState )
    case DEVICE_STATE_INIT:
#if(LORAWAN_DEVEUI_AUTO)
      //both set join DR and DR when ADR off
      LoRaWAN.setDefaultDR(3);
    case DEVICE_STATE_JOIN:
      LoRaWAN.join();
    case DEVICE_STATE_SEND:
      prepareTxFrame( appPort );
      LoRaWAN.send();
    case DEVICE_STATE_CYCLE:
    case DEVICE_STATE_SLEEP:
      LoRaWAN.sleep(loraWanClass);      // goto sleep - ESP32S3 in deep sleep
gives results
LoRaWAN joining transmitting etc 100mA
LoRaWAN.sleep() called 25uA
to measure microamp currents you need a good quality digital or analogue multimeter - I use an Avo 9mkII
EDIT: update using a Heltec WiFi32 LoRa V4 running above program
LoRaWAN joining transmitting etc 70mA
LoRaWAN.sleep() called 15uA
Note
in Tools menu select
for V4.3 LoRa FEM Type select USE_KCT8103L_PA.
if USE_NONE_PA (default) deep sleep current is 9mA
The problem with the v4.3.1 Version is VFEM_Ctrl. This one is active high so it stays on in deep sleep because of the pullup resistor at EN.
VFEM_Ctrl goes to GPIO 7 so you have to pull it down and keep it down in deep sleep.
Here’s some minimum code I wrote that does it properly and results in about 15uA in deep-sleep:
// === Radio Pins ===
#define RADIO_VFEM  7
#define RADIO_NSS   8
#define RADIO_RST   12
#define RADIO_BUSY  13
#define RADIO_DIO1  14
// ---- Display pins -----------------------------------------
#define VEXT_PIN 36
#define LED_PIN 35
SX1262 radio = new Module(RADIO_NSS, RADIO_DIO1, RADIO_RST, RADIO_BUSY);
void go_to_sleep(uint64_t sleepUs) {
  radio.sleep(); //  Put SX1262 into sleep
  //  Keep NSS and RST high and VFEM low and hold it during deep sleep
  pinMode(RADIO_NSS, OUTPUT);
  digitalWrite(RADIO_NSS, HIGH);
  pinMode(RADIO_RST, OUTPUT);
  digitalWrite(RADIO_RST, HIGH);
  pinMode(RADIO_VFEM, OUTPUT);
  digitalWrite(RADIO_VFEM, LOW);
  pinMode(VEXT_PIN, OUTPUT);
  digitalWrite(VEXT_PIN, HIGH);
  gpio_hold_en((gpio_num_t)VEXT_PIN);
  gpio_hold_en((gpio_num_t)RADIO_NSS);
  gpio_hold_en((gpio_num_t)RADIO_VFEM);
  gpio_deep_sleep_hold_en();    // keep the pins state while sleeping
  esp_sleep_enable_timer_wakeup(sleepUs);
  esp_deep_sleep_start(); // sleeps with aprox 15.5uA at 5V and 13.8uA at 3.3V
  setCpuFrequencyMhz(80);  // saves a lot of current while running
  gpio_deep_sleep_hold_dis();
  gpio_hold_dis((gpio_num_t)RADIO_VFEM);
  gpio_hold_dis((gpio_num_t)RADIO_NSS);
  gpio_hold_dis((gpio_num_t)RADIO_RST);
  gpio_hold_dis((gpio_num_t)VEXT_PIN);
  int state = radio.begin();  // needed to get it to sleep later
  // ======== do your stuff =========
  go_to_sleep(5000000);
