Heltec Wifi Kit V3 with code from V2 Problems
I’m a newbe, i’m sorry for my stupid questions…
I’m building a center of gravity scale for my model aircrafts.
I have 2 HX711 wight cells ans a Heltec Wifi Kit V3.
The Code is for a V2 and i have mdified the code so it compiles and i can upload it to the board but the screen is staying dark and i have no idea what i did wrong.
Any help is gratly apriciated.
// Visual Micro is in vMicro>General>Tutorial Mode
Created:  20.10.2019 13:22:22
Author:     WS-WSHOP\elsen
Updated: 01.12.2019
    - Added autoamtic zeroing after switching on ofer 50 measurement cycles
/// Used for deep sleep
#include “soc/rtc.h”;
/// Wifi setup
#include <WiFi.h>
#include <WiFiUdp.h>
const char * networkName = “Drcopter”; // WiFi network name and password:
const char * networkPass = “1234546789”;
const char * udpAddress = “255.255.255.255”;
const char * networkIP = “10.10.1.1”;
const int udpPort = 3333;
int RSSI = 0;
int RSSI_OLD;
byte packetBuffer[128]; //buffer to hold incoming and outgoing packets
String UDP_PACKET;
WiFiUDP udp;
boolean B_RECONNECT = false; // Is set to true when the connection gets lost because of RSSI Signal lost
boolean connected = false; // Are we currently connected?
boolean connected_old = true; // Previous state of the connected bool
/// OLED setup
#include <U8g2lib.h>
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=/ 21, / clock=/ 18, / data=*/ 17); // Full buffer rendering
/// Variables for the Display
unsigned long prevMillis = 0; // will store last time the display was updated
long DISPLAY_interval = 250; // transmit interval (milliseconds)
int inByte = 0; // incoming serial byte
char ver[] = “01.12.2019”; // Software version
boolean B_TX_INFO = true; // When the flag is set we send an info string to then PC
boolean B_TX_LOG = false; // When the flag is set we send a log message via udp
int UDP_TX_COUNT = 0; // Counts up every time a UDP-packet is send
int TX_INFO_INTERVALL = 20; // Every time UDP_TX_COUNT is greater than this the INFO packet will be sent
int N_PAGE = 2; // Display page (0=Setup, 1=Std Page, 2=Weight)
int N_PAGE_OLD = 4; // Display page (0=Setup, 1=Std Page, 2=Weight)
int N_PAGE_MAX = 3; // Max display page
int t_DISP_SLEEP = 600; // Time in Seconds after the display is set to power save mode in case no button is pressed
unsigned long T_DISPLAY_WAKEUP = 0; // Value set whenever a button is pressed
/// Setup the scale amps
#include “HX711.h”
HX711 scale_F;
HX711 scale_R;
/// Variables for the Scale filter intervall
unsigned long prMillis = 0; // will store last time the scale value was filtered
long T_SCALE_INT = 100; // Read and filter interval (milliseconds)
bool B_CALOFF_INPROGRESS = false; // Bool get’s set when offset measurement or calibration is ongoing
/// Setup EEPROM
#include “EEPROM.h”
#define EEPROM_SIZE 64
const int AD_OFFS_F = 1; // EEPROM address of front scale offset
const int AD_GAIN_F = 5; // EEPROM address of front scale gain
const int AD_OFFS_R = 13; // EEPROM address of rear scale offset
const int AD_GAIN_R = 17; // EEPROM address of rear scale gain
const int AD_L1 = 21; // EEPROM address of L1 (distance between the scales [mm])
const int AD_L2 = 25; // EEPROM address of L2 (distance between the front scale and the leading edge [mm])
/// Variables for the UDP transmit intervall
unsigned long previousMillis = 0; // will store last time the data was transmitted over serial
long UDP_Interval = 100; // transmit interval [ms]
/// Variables for Deep sleep button
int B_SLEEP_STATE; // the current reading from the input pin
int B_SLEEP_STATE_LAST = LOW; // the previous reading from the input pin
unsigned long lastDebounceTime = 0; // the last time the output pin was toggled
unsigned long debounceDelay = 2000; // the debounce time; increase if the output flickers
/// Variables for multi button
int B_MULTI_STATE; // the current reading from the input pin
int B_MULTI_STATE_LAST = LOW; // the previous reading from the input pin
unsigned long LDebTime = 0; // the last time the output pin was toggled
unsigned long DebDelay = 1; // the debounce time; increase if the output flickers
/// Misc Variables
float F_SCALE_F = 0; // Holds the filtered and calibrated value of the scale
int offset_F = 0; // Holds the scale offset
float gain_F = -0.00011; // Holds the scale gain
float F_SCALE_R = 0; // Holds the filtered and calibrated value of the scale
int offset_R = 0; // Holds the scale offset
float gain_R = -0.00011; // Holds the scale gain
float F_TOT = 0; // Holds the total aircraft weight
float CG = 0; // Holds the CG value
float L2 = 30; // Holds the length between the front measurement point and the leading edge stop
float L1 = 118; // Holds the length between the front and the rear scale
float U_BAT; // Holds the filtered supply battery voltage
int BAT_CHG_ST; // Battery charge state in percent
float BAT_CHG_ST_OLD = 101; // Holds the previous measured battery charge state in percent
float U_BAT_GAIN = 0.002635; // Gain [V/bit] to convert ADC input to V
char dispStr[6]; // null terminated char array used to pass to renderer
static const unsigned char CG_BASIS[] U8X8_PROGMEM = {
0x80, 0x1f, 0x00, 0xe0, 0x7f, 0x00, 0xf0, 0xf3, 0x00, 0xf8, 0xc3, 0x01,
0xfc, 0x03, 0x03, 0xfe, 0x03, 0x07, 0xfe, 0x03, 0x06, 0xff, 0x03, 0x06,
0xff, 0x03, 0x0c, 0xff, 0x03, 0x0c, 0x03, 0xfc, 0x0f, 0x03, 0xfc, 0x0f,
0x03, 0xfc, 0x07, 0x06, 0xfc, 0x07, 0x06, 0xfc, 0x07, 0x0c, 0xfc, 0x03,
0x18, 0xfc, 0x01, 0x70, 0xfc, 0x00, 0xe0, 0x7f, 0x00, 0x80, 0x1f, 0x00 };
static const unsigned char WEIGHT[] U8X8_PROGMEM = {
0x00, 0x02, 0x00, 0x80, 0x1f, 0x00, 0x80, 0x10, 0x00, 0xc0, 0x30, 0x00,
0xc0, 0x30, 0x00, 0xc0, 0x30, 0x00, 0xf0, 0xff, 0x00, 0xf0, 0xff, 0x00,
0xf8, 0xff, 0x01, 0xf8, 0xff, 0x01, 0xf8, 0xff, 0x01, 0xf8, 0xff, 0x03,
0xfc, 0xff, 0x03, 0xfc, 0xff, 0x03, 0xfc, 0xff, 0x03, 0xfe, 0xff, 0x07,
0xfe, 0xff, 0x07, 0xfe, 0xff, 0x07, 0xfe, 0xff, 0x07, 0xff, 0xff, 0x0f };
//** Setup *****************************************************************************************************************
void setup()
/// Serial port setup
Serial.println(“Booting…”);
/// The end of deep sleep
esp_sleep_enable_ext0_wakeup(GPIO_NUM_13, 1); //1 = High, 0 = Low
delay(100);
/// Slow down cpu to prevent glitches on HX711
setCpuFrequencyMhz(80);
/// Setup pins
pinMode(LED_BUILTIN, OUTPUT); // Active if UDP packet is transmitted
pinMode(3, OUTPUT); // HX711 supply
pinMode(32, INPUT); // Multi button
pinMode(13, INPUT); // Butto for deep sleep
/// Get EEPROM values
if (!EEPROM.begin(EEPROM_SIZE))
Serial.println("Failed to initialise EEPROM");
Serial.println("Restarting...");
delay(3000);
ESP.restart();
offset_F = EEPROM.readInt(AD_OFFS_F);
offset_R = EEPROM.readInt(AD_OFFS_R);
gain_F = EEPROM.readFloat(AD_GAIN_F) / 100000;
gain_R = EEPROM.readFloat(AD_GAIN_R) / 100000;
L1 = EEPROM.readFloat(AD_L1);
L2 = EEPROM.readFloat(AD_L2);
if (gain_F == NAN) gain_F = 1;
if (gain_R == NAN) gain_R = 1;
if (offset_F == NAN) offset_F = 0;
if (offset_R == NAN) offset_R = 0;
Serial.println("Scale front offset read from EEPROM is " + String(offset_F));
Serial.println("Scale rear offset read from EEPROM is " + String(offset_R));
Serial.println("Scale front gain read from EEPROM is " + String(gain_F * 100000));
Serial.println("Scale rear gain read from EEPROM is " + String(gain_R * 100000));
Serial.println("Scale L1 read from EEPROM is " + String(L1));
Serial.println("Scale L2 read from EEPROM is " + String(L2));
/// Start Display
u8g2.begin();
u8g2.enableUTF8Print();
u8g2.setFlipMode(1);
delay(10);
U_BAT = analogRead(1) * U_BAT_GAIN + 0.4; /// Calculate initial battery voltage
REFRESH_DISPLAY();
/// Start Wifi as AccessPoint
connectToWiFi_AP(networkName, networkPass);
udp.begin(WiFi.localIP(), udpPort); ///initializes UDP, this initializes the transfer buffer
/// Start Scale
digitalWrite(3, HIGH); /// Enable supply to HX711
scale_F.begin(4, 5); /// Start the front scale. Pinorder is SDA, SCK
scale_R.begin(6, 7); /// Start the rear scale. Pinorder is SDA, SCK
/// Zero the scales on startup
ZERO_SCALES(50);
//** Main void *************************************************************************************************************
/// UDP Packet receive
int packetSize = udp.parsePacket();
String UDP_RX_COMMAND = “”;
if (packetSize)
udp.read(packetBuffer, packetSize); /// read the packet into the buffer
for (int i = 1; i <= packetSize; i++)
  UDP_RX_COMMAND = UDP_RX_COMMAND + char(packetBuffer[i - 1]);
String POS = getValue(UDP_RX_COMMAND, ';', 0);
String CMD = getValue(UDP_RX_COMMAND, ';', 1);
String VALUE = getValue(UDP_RX_COMMAND, ';', 2);
   if ((POS == "0") && (CMD == "REB")) esp_restart();
else if ((POS == "0") && (CMD == "TAR")) ZERO_SCALES(VALUE.toInt());
else if ((POS == "0") && (CMD == "TARF")) ZERO_SCALEF(VALUE.toInt());
else if ((POS == "0") && (CMD == "TARR")) ZERO_SCALER(VALUE.toInt());
else if ((POS == "0") && (CMD == "CALF")) CALIBRATE_SCALE_F(VALUE.toFloat());
else if ((POS == "0") && (CMD == "CALR")) CALIBRATE_SCALE_R(VALUE.toFloat());
else if ((POS == "0") && (CMD == "INIT")) INIT_UNIT();
else if ((POS == "0") && (CMD == "INFO")) B_TX_INFO = true;
else if ((POS == "0") && (CMD == "SL1")) SETL1(VALUE.toFloat());
else if ((POS == "0") && (CMD == "SL2")) SETL2(VALUE.toFloat());
/// Debounce the ON/OFF Button and then send the unit to sleep
int reading = digitalRead(13);
if (reading != B_SLEEP_STATE_LAST)
lastDebounceTime = millis();
if ((millis() - lastDebounceTime) > debounceDelay) {
if (reading != B_SLEEP_STATE) {
  B_SLEEP_STATE = reading;
  if (B_SLEEP_STATE == HIGH)
    //GoToSleep();
B_SLEEP_STATE_LAST = reading;
if ((digitalRead(32) == HIGH) || (digitalRead(33) == HIGH))
  T_DISPLAY_WAKEUP = millis(); // Reset display wakeup time
  u8g2.setPowerSave(0);
// Timer
unsigned long currentMillis = millis();
/// Timer for Scale reading and filter
if (currentMillis - prMillis >= T_SCALE_INT)
  prMillis = currentMillis;
  if (B_CALOFF_INPROGRESS == false) CALC_SCALE_VALUE();
/// Timer for display refresh
if (currentMillis - prevMillis >= DISPLAY_interval)
  prevMillis = currentMillis;
  if (millis() > T_DISPLAY_WAKEUP + (t_DISP_SLEEP * 1000))
    u8g2.setPowerSave(1);
  else
    REFRESH_DISPLAY();
/// Timer for UDP transmit
if (currentMillis - previousMillis >= UDP_Interval)
  UDP_TX_COUNT++;
  if (UDP_TX_COUNT > TX_INFO_INTERVALL)
    UDP_TX_COUNT = 0;
    B_TX_INFO = true;
  RSSI = 100 - WiFi.RSSI() * -1;
  previousMillis = currentMillis;
  if ((connected) && (B_CALOFF_INPROGRESS == false))
    UDP_TX();
//** Subroutines *************************************************************************************************************
/// - CAL_SCALE_VALUE()
void CALC_SCALE_VALUE()
double ffactor = 1;
float F_SCALE_SAMPLE_F = (scale_F.read() - offset_F) * gain_F; //calculate weigth with gain and offset
int error = abs(F_SCALE_F - F_SCALE_SAMPLE_F);
if (error > 20)
ffactor = 0.8;
else if (error > 10 && error <= 20)
ffactor = 0.7;
else if (error > 1 && error < 10)
ffactor = 0.4;
else if (error < 1)
ffactor = 0.05;
F_SCALE_F = (1 - ffactor) * F_SCALE_F + ffactor * F_SCALE_SAMPLE_F;
if (F_SCALE_F == NAN) F_SCALE_F = 0;
if ((F_SCALE_F < 0) && (F_SCALE_F > -0.05)) F_SCALE_F = 0;
float F_SCALE_SAMPLE_R = (scale_R.read() - offset_R) * gain_R; //calculate weigth with gain and offset
error = abs(F_SCALE_R - F_SCALE_SAMPLE_R);
if (error > 20)
ffactor = 0.8;
ffactor = 0.7;
ffactor = 0.4;
else if (error < 1)
ffactor = 0.05;
F_SCALE_R = (1 - ffactor) * F_SCALE_R + ffactor * F_SCALE_SAMPLE_R;
if (F_SCALE_R == NAN) F_SCALE_R = 0;
if ((F_SCALE_R < 0) && (F_SCALE_R > -0.05)) F_SCALE_R = 0;
F_TOT = F_SCALE_F + F_SCALE_R;
if (F_TOT > 5)
CG = (F_SCALE_F * L2 + F_SCALE_R * L2 + F_SCALE_R * L1) / F_TOT;
else
CG = 0;
/// Display refresh u8g2-----------------------------------------------
void REFRESH_DISPLAY()
int x_start = 0;
u8g2.clearBuffer();
u8g2.setFont(u8g2_font_artossans8_8r); // 8X8 Font
u8g2.drawLine(0, 10, 128, 10);
int n_stations = WiFi.softAPgetStationNum();
char c_stations[2];
String(n_stations).toCharArray(c_stations, 8);
u8g2.drawStr(120, 8, c_stations);
u8g2.drawStr(0, 8, “WLAN CLIENTS:”);
// All 16x16 Font things happen from here onwards
u8g2.setFont(u8g2_font_helvB24_tr); // 18X18 Font
String(CG,1).toCharArray(dispStr, 8);
x_start = 137 - strlen(dispStr) * 18;
u8g2.drawStr(x_start, 38, dispStr);
u8g2.drawXBM(0, 17, 20, 20, CG_BASIS);
u8g2.drawXBM(0, 44, 20, 20, WEIGHT);
String((int)F_TOT).toCharArray(dispStr, 8);
x_start = 128 - strlen(dispStr) * 18;
u8g2.drawStr(x_start, 64, dispStr);
u8g2.sendBuffer();
///- UDP Data transmission ----------------------------------------
void UDP_TX()
String datastring;
if (B_TX_INFO)
datastring = "A;INFO;" + String(ver) + ";" + String(gain_F * 100000) + ";" + String(offset_F) + ";" + String(gain_R * 100000) + ";" + String(offset_R) + ";" + String(L1) + ";" + String(L2);
B_TX_INFO = false;
udp.beginPacket(udpAddress, udpPort);
udp.print(datastring);
udp.endPacket();
else if (B_TX_LOG){}
else
datastring = "A;VAL;" + String(F_SCALE_F) + ";" + String(F_SCALE_R) + ";" + String(CG) + ";" + String(F_TOT) + ";NULL;NULL;NULL";
udp.endPacket();
void UDP_TX_LOG(String txt)
B_TX_LOG = true;
delay(110);
String datastring = "A;LOG; " + txt + “;NULL;NULL;NULL;NULL;NULL;NULL”;
udp.endPacket();
B_TX_LOG = false;
// - Wifi connection routine -------------------------------------
/// If used as access point
void connectToWiFi_AP(const char * ssid, const char * pass)
Serial.println("Creating WiFi network: " + String(ssid));
// delete old config
WiFi.disconnect(true);
delay(50);
//register event handler
WiFi.onEvent(WiFiEvent_AP);
delay(50);
//Initiate connection
WiFi.softAPsetHostname(“OnTargetGW”);
IPAddress ip(10, 10, 1, 1);
IPAddress gateway(10, 10, 1, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.softAPConfig(ip, gateway, subnet);
WiFi.softAP(ssid, pass, 10, 0, 8);
delay(50);
Serial.println(“Waiting for WIFI client…”);
void WiFiEvent_AP(WiFiEvent_t event) {
switch (event)
case WIFI_EVENT_AP_STACONNECTED:
Serial.printf("Client connected to soft-AP = %d\n", WiFi.softAPgetStationNum());
delay(10);
connected = true;
case WIFI_EVENT_AP_STADISCONNECTED:
Serial.print("SYSTEM_EVENT_AP_STADISCONNECTED");
if (WiFi.softAPgetStationNum() == 0)
  connected = false;
  Serial.println("No station connected anymore");
else
  connected = true;
/// If used as client
void connectToWiFi_STA(const char * ssid, const char * pwd)
Serial.println(“Starting WiFi setup”);
delay(50);
delay(33);
WiFi.onEvent(WiFiEvent_STA);
delay(33);
WiFi.begin(ssid, pwd);
Serial.println(“Waiting for WIFI connection…”);
void WiFiEvent_STA(WiFiEvent_t event)
if ((N_PAGE > 0) && (N_PAGE < 3)) T_DISPLAY_WAKEUP = millis(); // Reset display wakeup time
switch (event)
case IP_EVENT_STA_GOT_IP: //When connected set
Serial.print("SYSTEM_EVENT_STA_GOT_IP: ");
Serial.println(WiFi.localIP());
connected = true;
delay(100);
B_RECONNECT = true;
case WIFI_EVENT_STA_DISCONNECTED:
Serial.println("SYSTEM_EVENT_STA_DISCONNECTED");
connected = false;
connectToWiFi_STA(networkName, networkPass);
case IP_EVENT_STA_LOST_IP:
Serial.println("SYSTEM_EVENT_STA_LOST_IP");
connected = false;
///- Go to sleep --------------------------------------------------
void GoToSleep()
u8g2.clearBuffer();
Serial.println(“Sleep Button detected, waiting for 2 seconds now…”);
UDP_TX_LOG(“Sleep Button detected, waiting for 2 seconds now…”);
u8g2.clear();
u8g2.drawStr(0, 16, “Switching”);
u8g2.setFont(u8g2_font_px437wyse700b_mr); // 16X16 Font
u8g2.drawStr(0, 32, "OFF ");
u8g2.sendBuffer();
delay(40);
u8g2.drawStr(0, 32, "OFF. ");
u8g2.sendBuffer();
delay(40);
u8g2.drawStr(0, 32, "OFF… ");
u8g2.sendBuffer();
delay(40);
u8g2.sendBuffer();
delay(40);
u8g2.sendBuffer();
delay(40);
u8g2.drawStr(0, 32, “OFF…”);
u8g2.sendBuffer();
Serial.println(“Going to sleep now”);
UDP_TX_LOG(“Going to sleep now”);
delay(100);
esp_deep_sleep_start();
//- Converters
String getValue(String data, char separator, int index)
int found = 0;
int strIndex[] = { 0, -1 };
int maxIndex = data.length() - 1;
for (int i = 0; i <= maxIndex && found <= index; i++)
if (data.charAt(i) == separator || i == maxIndex)
  found++;
  strIndex[0] = strIndex[1] + 1;
  strIndex[1] = (i == maxIndex) ? i + 1 : i;
return found > index ? data.substring(strIndex[0], strIndex[1]) : “”;
//- Calibration and zeroing ---------------------------------------
/// Zeroing
void ZERO_SCALES(int cycles)
B_CALOFF_INPROGRESS = true;
Serial.println(“Zero request received.”);
UDP_TX_LOG(“Zero request received”);
u8g2.clearBuffer();
u8g2.drawStr(8, 40, “ZEROING”);
u8g2.sendBuffer();
offset_F = scale_F.read_average(cycles);
F_SCALE_F = (scale_F.read() - offset_F) * gain_F; //calculate weigth with gain and offset
Serial.println("New offset calculated front: " + String(offset_F));
UDP_TX_LOG("New offset calculated front: " + String(offset_F));
EEPROM.writeInt(AD_OFFS_F, offset_F);
offset_R = scale_R.read_average(cycles);
F_SCALE_R = (scale_R.read() - offset_R) * gain_R; //calculate weigth with gain and offset
Serial.println("New offset calculated rear: " + String(offset_R));
UDP_TX_LOG("New offset calculated rear: " + String(offset_R));
EEPROM.writeInt(AD_OFFS_R, offset_R);
EEPROM.commit();
B_TX_INFO = true;
void ZERO_SCALEF(int cycles)
Serial.println(“Zero front request received.”);
UDP_TX_LOG(“Zero front request received.”);
u8g2.clearBuffer();
u8g2.drawStr(8, 40, “ZERO FT”);
u8g2.sendBuffer();
EEPROM.commit();
B_TX_INFO = true;
void ZERO_SCALER(int cycles)
Serial.println(“Zero rear request received.”);
UDP_TX_LOG(“Zero rear request received.”);
u8g2.clearBuffer();
u8g2.drawStr(8, 40, “ZERO RE”);
u8g2.sendBuffer();
EEPROM.commit();
B_TX_INFO = true;
/// Calibration
void CALIBRATE_SCALE_F(float calweight)
Serial.println(“Gain calibration request received.”);
UDP_TX_LOG(“Gain calibration request received.”);
delay(50);
u8g2.clearBuffer();
u8g2.drawStr(0, 40, “CAL FRT”);
u8g2.sendBuffer();
gain_F = calweight / (offset_F - scale_F.read_average(15)) * -1;
EEPROM.writeFloat(AD_GAIN_F, gain_F * 100000);
EEPROM.commit();
Serial.println("New front gain calculated: " + String(gain_F * 100000));
UDP_TX_LOG("New front gain calculated: " + String(gain_F * 100000));
B_TX_INFO = true;
void CALIBRATE_SCALE_R(float calweight)
delay(50);
u8g2.clearBuffer();
u8g2.drawStr(0, 40, “CAL REAR”);
u8g2.sendBuffer();
gain_R = calweight / (offset_R - scale_R.read_average(15)) * -1;
EEPROM.writeFloat(AD_GAIN_R, gain_R * 100000);
EEPROM.commit();
Serial.println("New rear gain calculated: " + String(gain_F * 100000));
UDP_TX_LOG("New rear gain calculated: " + String(gain_F * 100000));
B_TX_INFO = true;
void SETL1(float distance)
L1 = distance;
EEPROM.writeFloat(AD_L1, distance);
EEPROM.commit();
Serial.println("New L1 written to EEPROM: " + String(distance));
UDP_TX_LOG("New L1 written to EEPROM: " + String(distance));
B_TX_INFO = true;
void SETL2(float distance)
L2 = distance;
EEPROM.writeFloat(AD_L2, distance);
EEPROM.commit();
Serial.println("New L2 written to EEPROM: " + String(distance));
UDP_TX_LOG("New L2 written to EEPROM: " + String(distance));
B_TX_INFO = true;
// Init new unit to gain 1 and offset 0. Reboot after.
void INIT_UNIT()
Serial.println(“Unit initialisation command received.”);
UDP_TX_LOG(“Unit initialisation command received.”);
delay(50);
u8g2.clearBuffer();
u8g2.drawStr(22, 32, “INIT”);
u8g2.sendBuffer();
EEPROM.writeInt(1, 0);
EEPROM.writeInt(13, 0);
EEPROM.writeFloat(5, 1);
EEPROM.writeFloat(17, 1);
EEPROM.commit();
Serial.println(“Done, restarting now…”);
UDP_TX_LOG(“Done, restarting now…”);
esp_restart();
