Hello everyone,
Can someone help me figure out how to connect a scd40 sensor the the heltec V4?
I tried using an I2C scanner but it does not pick up my sensor, so I’m guessing that I am initialising the second bus incorrectly or using the wrong GPIO pins. I don’t want to use pins 17/18 that the OLED screen uses since I did not solder them on (don’t have a soldering kit at home).
Any help is appreciated, thank you!
