I purchased 2 Heltec V3 LoRa 32. I have successfully installed the software and uploaded a basic Arduino program. When powered with the computer USB everything works fine.
I tried to build a voltage regulator circuit where I use a rechargeable 9V battery as the input power. The circuit looks like the following:
The diagram above is found here:
https://electronics.stackexchange.com/questions/148340/how-to-protect-lm317-from-output-short
The completed circuit I built outputs 3.7V. When connected to the circuit through the battery connector the Heltec display keeps blinking and the program does not load. If I go back to using the computer USB the program loads again, no problem.
Maybe there is something in the circuitry that doesn’t like this type of power source? The blinking display is the only clue I have. Any troubleshooting ideas would be appreciated.
