I have been trying to get my 2 Heltec V3 Lora 32 devices to work for the last week. I am TOTALLY FRUSTRATED since I CANNOT connect the board serially (fails each time. Have installed correct driver), cannot COMPILE any sketch with the same error message (shown below) unless I try using a Lora32 V2 board and then I get a wrong ESP32 error message and have tried 2 PCs, new type-c cables, deleted Arduino IDE and re-installed IDE about 25 times, gone through your protocol to install the V3 software and have COMPLETELY RUN OUT OF IDEAS. I cannot believe I am the ONLY person having these issues. If I CANNOT get this device working soon, the devices are going back to AMAZON for a complete refund. I have NEVER had an Arduino experience like this and I am NOT HAPPY. I am too old (79 years) to have to put up with this incompetence (am a retired Electrical Engineer with years of computer experience!!).
Here are my error messages:
#1 Error Message (Compiling with WiFi LORA 32(V3) board):
In file included from c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\string:41,
from c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\stdexcept:39,
from c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\array:39,
from c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\tuple:39,
from c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\functional:54,
from C:\Users\Dell Optiplex\AppData\Local\Arduino15\packages\Heltec-esp32\hardware\esp32\0.0.7\cores\esp32/HardwareSerial.h:49,
from C:\Users\Dell Optiplex\AppData\Local\Arduino15\packages\Heltec-esp32\hardware\esp32\0.0.7\cores\esp32/Arduino.h:173,
from C:\Users\Dell Optiplex\AppData\Local\Temp\arduino-sketch-DA6E3C8473B3DAF0916C1101C8B3E1E7\sketch\Blink.ino.cpp:1:
c:\users\dell optiplex\appdata\local\arduino15\packages\heltec-esp32\tools\xtensa-esp32s3-elf-gcc\gcc8_4_0-esp-2021r2-patch3\xtensa-esp32s3-elf\include\c++\8.4.0\bits\allocator.h:46:10: fatal error: bits/c++allocator.h: No such file or directory
#include <bits/c++allocator.h> // Define the base class to std::allocator.
compilation terminated.
exit status 1
#2 Error Message (compiling with WiFi LORA 32 board):
Sketch uses 219053 bytes (16%) of program storage space. Maximum is 1310720 bytes.
Global variables use 16088 bytes (4%) of dynamic memory, leaving 311592 bytes for local variables. Maximum is 327680 bytes.
esptool.py v3.3
Serial port COM8
ConnectingâŠ
A fatal error occurred: This chip is ESP32-S3 not ESP32. Wrong --chip argument?
Failed uploading: uploading error: exit status 2
