try
// Heltec LoRa V3 OLED and BME280 test
// Heltek LoRa V3 SDA: 41 SCL: 42
// BME280 setup
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define SEALEVELPRESSURE_HPA (1013.25)
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
unsigned long delayTime;
// OLED setup
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128 // OLED display1 width, in pixels
#define SCREEN_HEIGHT 64 // OLED display1 height, in pixels
// Declaration for an SSD1306 display1 connected to I2C (SDA, SCL pins)
#define SCREEN_ADDRESS 0x3C //0x3D ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
// use Wire1 for OLED display as BMP280 is using Wire and would conflict (only one works)
Adafruit_SSD1306 display1(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire1, RST_OLED);
Serial.println();
Serial.println(F("Heltec LoRa V3 OLED and BME280"));
bool status;
// default settings
// (you can also pass in a Wire library object like &Wire2)
status = bme.begin(0x76);
if (!status) {
Serial.println("Could not find a valid BME280 sensor, check wiring!");
while (1);
Serial.println("-- Default Test --");
delayTime = 1000;
Serial.println();
// OLED setup
// setup OLED display
Wire1.begin(SDA_OLED, SCL_OLED);
// SSD1306_SWITCHCAPVCC = generate display1 voltage from 3.3V internally
if (!display1.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) {
Serial.println(F("SSD1306 allocation failed"));
for (;;)
; // Don't proceed, loop forever
Serial.println(F("SSD1306 allocation OK"));
// Show initial display1 buffer contents on the screen --
// the library initializes this with an Adafruit splash screen.
//display1.display();
delay(2000); // Pause for 2 seconds
display1.clearDisplay();
display1.setTextSize(2); // Normal 1:1 pixel scale
display1.setTextColor(SSD1306_WHITE); // Draw white text
display1.setCursor(0, 0); // Start at top-left corner
display1.println(F(" Heltec V3\n BME280"));
display1.display();
delay(2000);
printValues();
delay(delayTime);
void printValues() {
float temperature, pressure, humidity;
Serial.print("Temperature = ");
Serial.print(temperature=bme.readTemperature());
Serial.println(" *C");
// Convert temperature to Fahrenheit
/*Serial.print("Temperature = ");
Serial.print(1.8 * bme.readTemperature() + 32);
Serial.println(" *F");*/
Serial.print("Pressure = ");
Serial.print(pressure = (bme.readPressure() / 100.0F));
Serial.println(" hPa");
Serial.print("Approx. Altitude = ");
Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
Serial.println(" m");
Serial.print("Humidity = ");
Serial.print(humidity=bme.readHumidity());
Serial.println(" %");
Serial.println();
// display results on OLED
Serial.println(); // start a new line
display1.clearDisplay(); // Dsiplay information
display1.setTextSize(1);
display1.println("Heltec BME280\n");
//display1.setCursor(0, 20);
display1.printf("Temperature %.2f\n\n", temperature);
// display1.setCursor(0, 40);
display1.printf("Pressure %.2f\n\n", pressure);
display1.printf("Humidity %.2f\n\n", humidity);
display1.display();
delay(2000); // wait 2 seconds
serial monitor output
– Default Test –
Temperature = 22.33 *C
Pressure = 1021.14 hPa
Approx. Altitude = -65.49 m
Humidity = 51.71 %
Temperature = 22.32 *C
Pressure = 1021.16 hPa
Approx. Altitude = -65.65 m
Humidity = 51.52 %
