hi
im trying to see what changed on the V3.2 as I can flash it normally and SPIFFS writing is not being achieved with Platformio + VSCODE for this board
hi
Well, believe it or not, they inverted the control logic for Vext, so that may be biting you. Perhaps check the board schematic (note that, at the time of writing, this is not the schematic you will get if you follow the link on their product information page!) for anything else that might be impacting what you are doing.
great info:
changing VEXT “polarity” worked like a charm
@Heltec : there should be a cleaner way of discovering what have been changed on each version
Hello, heltec v3.2 has made the following changes:
The most important point is:
also got it right
THANKS
