I have erase & reflashed several times. I was able to access via BT after the first time FW was installed, but I entered network info then I could not reach the device using IP or meshtastic.local. Finally did via the client but it did not load correctly. Reflashed and RST light blinks constantly and it will not allow me to link via BT. I get “No device connected” error message although I see the unit as being available to link to. I can see the device via a serial connection, but it won’t even allow me to save the network info. I click save icon at top right, but, when I come back to Network page, it’s missing.
Heltec Tracker v1.1: RST light flashing / no bluetooth
SOLVED: Went into phone’s BT connections and removed prior connection that had worked. Once I did that and restarted, I was able to get random passcode and relink to Tracker via BT. BTW, RST light is still flashing…
