I’m having trouble getting a 3.7v LiPo battery to charge on a solar powered Meshtastic node.
When I replaced the 5W 5v solar panel with an adjustable power supply I discovered the charge rate dropped to almost zero at 5.0 volts input.
The orange LED would light but no useful charging would happen until I raised the voltage to 5.1 volts.
My two RAK nodes don’t appear to have this behavior.
Heltec T114 solar charge issue
For what it’s worth, the recommended solar panel voltage on other Heltec boards, the CubeCell for example, is 5.5-7V.
Thanks for the input. The 5W solar panel I’m using is designed for USB voltage (~5.1V).
The LGS4056H datasheets are all in Chinese, so I am unable to look for a modification to the charge controller.
If they are “designed” for USB voltage that means you’ve got something in the way converting the output to 5.1V - usually a small white plastic box with a USB type A. Some surgery will be required to remove it and have a direct connection.
We can’t run a direct connection as there is an upper input limit of 7 volts. Most of these panels can do twice that unregulated.
On the panels I’m using the regulator is in the plastic welded case and I don’t want to lose the water tight integrity.
I’ll probably have to source another unregulated 5W panel and add the buck circuitry or linear regulator.
And you may well be back in the same place with far less efficient as they won’t be able to optimise the voltage / current balance.
Read up on solar - most panels on a multimeter give out much larger than advertised voltages - its the voltage under a load that counts - many of us use off-the-shelf panels that are advertised as 5V, 5.5V or 6V - as long as under reasonable sunshine they can deliver over 4V, the 4056 chip will do fine.
“as long as under reasonable sunshine they can deliver over 4V, the 4056 chip will do fine.”
The delta V will increase as the battery level drops - I’m hoping that I will simply have to live with less than 100% charge.
Time will tell - stay tuned.
Fully charged LiPo to 4.2V = 200 to 300 cycles, NASA charged LiPo to 3.9V = +1000 cycles, YMMV, sure, only 80% capacity but so much longer lifespan - just size up the LiPo a little bit.
