Heltec stick lite V3 looses memory
my Heltec stick lite V3 will loose part of is memory when the battery dies when using meshtastic. After flashing the most recent firmware, I changed the user name, but after a battery drain, it lost the user name and went back to the default name. Has anyone found a solution to this problem besides not allowing the battery to die?
Observe when the battery dies does the BMS keep waking the unit back up if only briefly? I had a problem with a particular BMS and a lora v3 where it would corrupt the flash due to rapid powercycling by the BMS when the battery was “empty”. A better more reliable BMS was the solution in my case.
Thanks for the information.
