I hope this code can provide you with some help. You can use this code to meet your requirements on Arduino.
Blockquote
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
#include <SPI.h>
#include <Adafruit_NeoPixel.h>
#include <Arduino.h>
#define PIN 14 // On Trinket or Gemma, suggest changing this to 1
#define NUMPIXELS 2 // Popular NeoPixel ring size
const int echoPin = 16;
const int trigPin = 13;
Adafruit_ST7789 tft = Adafruit_ST7789(&SPI1, PIN_TFT_CS, PIN_TFT_DC, PIN_TFT_RST);
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
void setup(void) {
pinMode(21,OUTPUT);//Enable Vext
digitalWrite(21,1);
pixels.begin(); // INITIALIZE NeoPixel strip object (REQUIRED)
pixels.clear(); // Set all pixel colors to ‘off’
Serial1.begin(115200);
pinMode(trigPin, OUTPUT);
pinMode(echoPin, INPUT);
pinMode(PIN_TFT_VDD_CTL, OUTPUT); // TFT VDD ENABLE
digitalWrite(PIN_TFT_VDD_CTL, 0);
pinMode(PIN_TFT_LEDA_CTL, OUTPUT); // LEDA ENABLE
digitalWrite(PIN_TFT_LEDA_CTL, 0);
Serial.print(F(“Hello! ST77xx TFT Test”));
tft.init(135, 240); // Init ST7789 240x135
tft.setRotation(3); // Set screen rotation
tft.setSPISpeed(40000000); // SPI speed
Serial.println(F(“Initialized”));
tft.fillScreen(ST77XX_BLACK); // Clear the screen
tft.setTextColor(ST77XX_WHITE); // Set text color to white
tft.setTextSize(2); // Set text size
tft.setCursor(50, 60); // Set cursor position
tft.print(F(“Hello”)); // Print “Hello” on the screen
delay(2000);
typedef enum
ORANGE,
RED,
BLUE_GREEN,
GREEN
}Color_t;
Color_t color;
#define VALUE 51
void RGB_Color(uint8_t color, uint8_t value)
switch(color)
case ORANGE:
pixels.setPixelColor(0, pixels.Color(value * 5, value, 0));
pixels.setPixelColor(1, pixels.Color(value * 5, value, 0));
pixels.show();
case RED:
pixels.setPixelColor(0, pixels.Color(value * 5, 0, 0));
pixels.setPixelColor(1, pixels.Color(value * 5, 0, 0));
pixels.show();
case BLUE_GREEN:
pixels.setPixelColor(0, pixels.Color(0, value * 5, value * 2));
pixels.setPixelColor(1, pixels.Color(0, value * 5, value * 2));
pixels.show();
case GREEN:
pixels.setPixelColor(0, pixels.Color(0, value * 5, 0));
pixels.setPixelColor(1, pixels.Color(0, value * 5, 0));
pixels.show();
// Clear screen and show title
tft.setTextSize(2);
tft.setCursor(10, 10);
tft.println(“Ultrasonic Sensor”);
// Trigger the ultrasonic sensor
digitalWrite(trigPin, LOW);
delayMicroseconds(2);
digitalWrite(trigPin, HIGH);
delayMicroseconds(10);
// Measure the pulse width of the echo signal
long duration = pulseIn(echoPin, HIGH);
// Calculate the distance (in cm)
long distance = duration * 0.0343 / 2;
// Print the distance on the Serial Monitor
Serial.print(“Distance: “);
Serial.print(distance);
Serial.println(” cm”);
// Display the distance on the TFT screen
tft.setCursor(10, 50); // Set cursor for the distance text
tft.fillRect(10, 50, 200, 40, ST77XX_BLACK); // Clear previous data
tft.print(“Distance: “);
tft.print(distance);
tft.println(” cm”);
// Change LED color based on distance
if (distance < 50) {
RGB_Color(RED, VALUE); // Less than 50cm, red
else if (distance >= 50 && distance < 100) {
RGB_Color(ORANGE, VALUE); // 50 to 100cm, orange
else if (distance >= 100 && distance < 150) {
RGB_Color(BLUE_GREEN, VALUE); // 100 to 150cm, blue-green
else {
RGB_Color(GREEN, VALUE); // Greater than 150cm, green
delay(1000); // Update once every second
