I could to the gateway via the wifi on IP address factory default 192.168.4.1. I switched the “net settings” from wifi client to eth-wan. The system prompted for a reboot and rebooted. The device is now seemingly non-responsive. The device no longer broadcasts its SSID and therefore, I cannot connect to the main configuration page via wifi.
As a basic troublshooting step, I cannot find the MAC on the router that the gateway is currently plugged into which implies that DHCP is no longer working.
I have tried to connect to the main configuration page via the ethernet port directly connected to my laptop using a 192.168.4.200 address. There is no response on 192.168.4.1 when I use my laptop.
I have not changed any other network configuration on this device (except the things network configuration below).
https://docs.heltec.org/en/gateway/ht-m02_v2/quick_start.html#eth-wifi-version
Which IP address is the ethernet port configured with when in this network configuration?
Which IP address should I use to connect to the gateway?
How would I use the serial port to change the net settings back to the wifi client configuration?
