Heltec LoRa32 V3.1 PRG button
~URGENT… need this done by late afternoon tommorrow~
Hi all, as part of my on going project, i’m doing a panic mode using the LoRa32 V3 board and its PRG Button to activate it. Used to got it working and pretty sure the assignment for it was GPIO 0. Pressing the PRG button does nothing now, only the RST button works. anyone has a solution or answer for it?
I have also tested it on 3 different V3 boards, no luck…
const int PRG_BUTTON_PIN = 0;
Without knowing how you are checking the pin it’s going to be super hard to assist.
Is there a reward or bounty for answering in time?
i managed to fixed it, it just required more code that was missing haha.
@ogta - I’m facing the same issue for my project. Please could you share the additional code which was missing? What did you need to add to get it working?
Thanks,
Dom
