Heltec LoRa32 V2 communication HT-M01S (Rev.2.0)
Good day, I would like to know if the data transmission through HT-M01S (Rev.2.0) is compatible.
I am using a Heltec LoRa32 V2 as a node and I would like to change my Gateway (Mikrotik) for something a little cheaper but that maintains certain amounts of connection (30 or 50 devices).
Your answer would be of great help to be able to say, I appreciate your time. Thank you very much.
Are you using TTN as a backend?
@luis-santajuliana
HT-M01S (Rev.2.0) conforms to standard lorawan, all nodes that conform to standard lorawan can be connected. Gateways can establish connections with dozens of nodes.
@navi
Great, thank you very much for your answer.
@johan-scheepers
I’m using Chirpstack.
