Heltec Lora v4 VSCode library support
Hi everyone,
I really enjoy my Lora v4 hardware, but I would like to know if anyone has successfully try to at least compile and build lora examples from Heltec in VisualStudio Code, I did try severals things (linking heltec libraries, add build args, defines somes variables). All I can do at the end is to pass compile and send but at reboot Lora v4 get stuck.
With arduinoIDE, no problem for now.
Thank you.
use the Heltec V3.2 and should work (at least without GPS)
Reading this, I again wonder when Heltec will deliver a reasonable support / documentation for its boards.
